Topic: Common anode RGB LED (Read 13023 times) previous topic - next topic
FallenDemon
Mike I replaced every single Serial with mySerial and I am still getting the error on this
Code: [Select]
ANdroid.ino: In function 'void loop()':
ANdroid:88: error: 'class SoftwareSerial' has no member named 'parseInt'
ANdroid:92: error: 'class SoftwareSerial' has no member named 'parseInt'
ANdroid:96: error: 'class SoftwareSerial' has no member named 'parseInt'
ANdroid:101: error: 'class SoftwareSerial' has no member named 'parseInt'
ANdroid:105: error: 'class SoftwareSerial' has no member named 'parseInt'
ANdroid:109: error: 'class SoftwareSerial' has no member named 'parseInt'
jack wp
Come on guys. We are no longer discussing the subject of this thread "Common anode RGB LED". It is time to close this thread, tag it as (SOLVED), and create a new thread.
runaway_pancake
It's FallenDemon's deal, still related though; going the holistic route.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
FallenDemon
Quote
I need help. Is this thread bothering you? Does it hurt you in any way?
Grumpy_Mike
Code: [Select]
So can you post the code of this so we can try ourselves.
FallenDemon
Code: [Select]
//pins for the LEDs:
const int redPin = 3;
const int greenPin = 5;
const int bluePin = 6;
const int redPin2 = 9;
const int greenPin2 = 10;
const int bluePin2 = 11;
#define REDPIN 3
#define GREENPIN 5
#define BLUEPIN 6
#define FADESPEED 5
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
// initialize serial:
mySerial.begin(9600);
// make the pins outputs:
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
pinMode(redPin2, OUTPUT);
pinMode(greenPin2, OUTPUT);
pinMode(bluePin2, OUTPUT);
mySerial.print("Arduino control RGB LEDs Connected OK ( Sent From Arduinno Board )");
mySerial.print('\n');
// if there's any serial available, read it:
while (mySerial.available() > 0) {
// look for the next valid integer in the incoming serial stream:
int red = mySerial.parseInt();
// do it again:
int green = mySerial.parseInt();
// do it again:
int blue = mySerial.parseInt();
int red2 = mySerial.parseInt();
// do it again:
int green2 = mySerial.parseInt();
// do it again:
int blue2 = mySerial.parseInt();
// look for the newline. That's the end of your
// sentence:
if (mySerial.read() == '\n') {
   // constrain the values to 0 - 255 and invert
   // if you're using a common-cathode LED, just use "constrain(color, 0, 255);"
   //red = 255 - constrain(red, 0, 255);
   //green = 255 - constrain(green, 0, 255);
   //blue = 255 - constrain(blue, 0, 255);
red = constrain(red, 0, 255 );
green = constrain(green, 0, 255);
blue = constrain(blue, 0, 255);
red2 = constrain(red2, 0, 255);
green2 = constrain(green2, 0, 255);
blue2 = constrain(blue2, 0, 255);
   // fade the red, green, and blue legs of the LED:
analogWrite(redPin, (255 - red));
analogWrite(greenPin, (255 - green));
analogWrite(bluePin, (255 - blue));
analogWrite(redPin2, (255 - red));
analogWrite(greenPin2, (255 - green));
analogWrite(bluePin2, (255 - blue));
   // print the three numbers in one string as hexadecimal:
mySerial.print("Data Response : ");
mySerial.print(red, HEX);
mySerial.print(green, HEX);
mySerial.println(blue, HEX);
runaway_pancake
I hope you don't mind, but I took out a lot of spaces and re-formatted your code; not to be picky, but to facilitate legibility.  Demonstrates how, I think, those in the know expect to see things and which is all the more conducive to eliciting the help you seek.
Code: [Select]
#define REDPIN 3
#define GREENPIN 5
#define BLUEPIN 6
#define FADESPEED 5
    // look for the newline. That's the end of your sentence:
      // red = 255 - constrain(red, 0, 255);
      // green = 255 - constrain(green, 0, 255);
      // blue = 255 - constrain(blue, 0, 255);
jack wp
Quote
One of the main reasons I suggested starting a new thread, describing your current question, is to get you help on the current question. There may be people that have experience, and can give you help (not to say the guys working on it now can't), but, not finding your subject in an appropriate section, they never know to read the "Common anode RGB LED" thread.
First priority was, to get you help on the subject you need it on.
Second priority was, not to needlessly take up time for people that want to help with "Common anode RGB LED", by having to read many posts before they find out that that problem has already been fixed.
I wish you luck with your query. Jack
FallenDemon
Well understandable but you could have worded it differently. Mike did you get a chance to test that code?
Grumpy_Mike
Well you have the line
Code: [Select]
Those pins do not exist on the ATtiny84.
Have you seen:-
http://projectsfromtech.blogspot.co.uk/2013/06/serial-communication-on-attiny85-with.html
FallenDemon
Mike I did see that and it says that the Softwareserial will work with parseInt() however I am getting the error still. I changed the pins to 2, and 3 respectively. I don't know why it is still complaining about parseInt()???
runaway_pancake
No consolation, but it compiles successfully with Uno selected.
FallenDemon
Yes it does lol. I even tried the example sketch that Mike gave me from http://projectsfromtech.blogspot.co.uk/2013/06/serial-communication-on-attiny85-with.html. It complains about parseInt() and yes I am burning the bootloader to 8mHZ in order to enable softwareSerial support on the attiny chip. Yet it complains saying 'class SoftwareSerial' has no member named 'parseInt' I been trying this for 3 days and I am really close just need to get past this silly error!
jack wp
I hate to say "I told you so", but if you had changed the thread from "common anode RGB LED" three days ago, to the real current problem, who knows, maybe someone would have found it that knew the answer. But, again, that's just my opinion.
runaway_pancake
I hate to say "I told you so",...
Now you're just being a pill.
