Topic: format of the bitmap .c file (Read 4080 times) previous topic - next topic
ChPr
Hello everybody,
In a .c file created with "ImageConverter 565" that represent a bitmap, I like to know what represent each word. For instance, in this file, are each word a color value, an address, a mix ?
// Generated by  : ImageConverter 565 v1.2
// Generated from: yyy.gif
// Time generated: 27/08/2013 20:13:05
// Dimensions    : 4x12 pixels
// Size          : 96 Bytes
#include <avr/pgmspace.h>
prog_uint16_t yyy[0x30] PROGMEM ={
0xB5B5, 0xDED5, 0xFFFF, 0xFFFF, 0xFFFF, 0x0000, 0xFFFF, 0xFFFF, 0xFFFF, 0x6B6A, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B5, 0xFFFF, 0xFFFF,   // 0x0010 (16)
0xFFFF, 0xDEDF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x9495, 0xFFFF, 0xFFFF, 0xFFFF, 0x6B6A, 0xFFFF, 0xFFFF, 0xFFFF, 0x2120, 0xFFFF,   // 0x0020 (32)
0xFFFF, 0xFFFF, 0x212A, 0xFFFF, 0xFFFF, 0xFFFF, 0x4A4A, 0xFFFF, 0xFFFF, 0xFFFF, 0x9495, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x4A4A,   // 0x0030 (48)
Thanks for your help.
Pierre
Pourquoi faire simple alors qu'il est si facile de faire compliqué !
holmes4
GIF's are not "bitmaps" from the size it looks like a simple dump of the if, in which case you need to look up the gif documentation to understand the data.
Mark
ChPr
Here is the file got from the corresponding bmp file :
// Generated from: yyy.bmp
// Time generated: 27/08/2013 20:49:50
// Size          : 96 Bytes
Is is exactly the same. So I dont think that the original format as any exffect on the .c file.
Pierre
majenko
It looks to me to be raw image data.
The image, as the comments show, is 4x12 pixels.  4x12 = 48.
The data is 96 bytes.  96 / 48 = 2.  So two bytes per pixel.  Given the name of the program, that's what I'd expect.
565 is a 16-bit RGB colour space definition - 5 bits of red, 6 of green (the eye is more sensitive to green) and 5 of blue: RRRRRGGG GGGBBBBB
So each word is a single pixel in 565 RGB format, probably in a left-to-right, top-to-bottom arrangement.
holmes4
From (what I think) is the right webpage.
http://www.henningkarlsen.com/electronics/t_imageconverter565.php
This tool can be used to convert images into the formats required for my UTFT libraries for
So it could be any thing - but majenko may well be right.
Mark
leonelpepe
You can try do a simple test. Pass to this tool a picture with RED, GREEN and BLUE squares in a simple size and just see the output.
Bye
majenko
If I am right, the image you have there should look like this: but I'm not sure that's right.  Maybe if you did a larger image I could test it better.
holmes4
The UTFT lib may allow "a transparent" pixel, not just colors.
Mark
doc_norway
You couldn't be more correct :)
Each word is a RGB565 encoded value for a pixel starting from the upper left corner, going alone each line to end up in the lower right corner.
UTFT does not support transparency.
/Henning
