Topic: usb communication with c++ (Read 5384 times) previous topic - next topic
naeemuzz
kindly help me to get data from the uno to my lap working on ubuntu 12.04. i am creating a program interfacing a camera in c++. i want to include a segment ie to get data from uno and use it manipulate the configurations of camera.kindly help...
Erdin
The Arduino Uno creates a (virtual) serial port on the PC.
That serial port is used to upload a sketch and also to read from and write to the Arduino Uno.
http://arduino.cc/en/reference/serial
There are many ways to use that serial port on the PC, for example in C++ but also the command line and some use python.
naeemuzz
ok..thanks for the help :)..i have tried the following..
configured baudrate in terminal by
stty -F /dev/ttyACM0 9600
then i created a c++ program(exp.cpp) in my computer
#include<iostream>
#include<fstream>
#include<string>
using namespace std;
int main()
string str;
fstream f;
f.open("/dev/ttyACM0");
while(1)
   while (f >> str)
      cout << str;
return 0;
and uploaded this program into arduino uno
int led = 13;
  pinMode(led, OUTPUT);
  digitalWrite(led, HIGH);
  Serial.write("led");
  digitalWrite(led, LOW);
finally compiled the exp.cpp and got nothing...please consider me as newbie to usb communication
naeemuzz
well i changed the c++ program as
#include<iostream>
#include<fstream>
int main()
char ch;
ifstream f;
   while (f.get(ch))
      cout << ch;
return 0;
when i compile the program i get
naaeemuzz@naaeemuzz-Satellite-L655:~/project/samples$ ./samplesled
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
led
and this happens in split of a  second and stops.i actually wanted an output similar to that of serial monitor..ie whenever the led blinks and shows out:"led" and else it does not....so what should i do??
Erdin
The Uno keeps sending "led" every 2 seconds. I think that part is good.
Your program on PC ends when there is nothing to receive.
Perhaps you can test if a keyboard button is pressed to end the program.
What kind of compiler do you use for the PC program ?
naeemuzz
i use g++ compiler...i compiled through terminal...lemme try about what you told...
naeemuzz
i programmed cpp file as when it gets input "1",it shows output from uno,still the program stopes  in 2 sec.. :(
Erdin
I tried to make a program in C++.
But it is not reading /dev/ttyACM0. I get a lot of EOF, and nothing else.
naeemuzz
Erdin
I'm sorry, but I don't know.  :~
I wanted to test the communication, but somehow I am not receiving anything with my c++ program.
I have not made a c++ program on the PC for the serial port before.
Normal programs like gtkterm can communicate without problem.
makerman
A quick search on google found these candidates:
http://www.teuniz.net/RS-232/
http://sourceforge.net/projects/cssl/
I have not used them, but you can give them a try.
naeemuzz
well thanx for your support...when i searched in stackoverflow.com i got a solution perfectly working...problem was the part where i configured baudrate..
i used
stty -F /dev/ttyACM0 sane raw pass8 -echo -hupcl clocal 9600
this works well
source:http://stackoverflow.com/questions/11677639/two-way-c-communication-over-serial-connection
