Topic: 3-digit, 7-segment display (one unit) questions/help.. (Read 8177 times) previous topic - next topic
xl97
#15
Aug 31, 2013, 03:42 pm Last Edit: Aug 31, 2013, 04:04 pm by xl97 Reason: 1
so this morning.. i was attempting to drop the via (like you suggested)..
dropped on in the lower/left corner..
and the RATSNESt turns on.. (showing the GND polys).. and the air/wire/line)
I connect the line to the closest 'GND' connection according to Eagle..
once done though.. there are other air-wires... like I need to connect ALL GND points or something to that VIA?
In still not 100% clear on WHY I am doing this? I dont believe I have any isolated areas?  and the planes run around/outside all the traces?
anyways.. here is a quick image of what Im talking about..
if I connect that via to the closest GND point (which is GND pin on the MAX chip)..  I still get the lines that I need to connect it to the other GND points too?
I have attached my FINAL (current) board files...
the only thing that I am leery about is this GND via?
check it out and let me know....(curious as to why dropping a GND via to connect GNDs on both sides.. makes me draw 4-5 more traces?  shouldnt it just connect to the HUGE GND plane? that those other components are connected to as well??
* Im starting to overthink my other PCb project too now.. (the one with MAX chip but 30 SMD leds instead of a numeric display)...  I dont believe I manually dropped any GND vias??
wouldnt the error checker alert the user to this is needed/missed?
thanks..
CrossRoads
Let autoroute now - should make the Gnd connections to the plane for you.
Thats all I did with the one I posted earlier.
