Topic: 3-digit, 7-segment display (one unit) questions/help.. (Read 8041 times) previous topic - next topic
xl97
Aug 28, 2013, 10:06 pm Last Edit: Aug 28, 2013, 10:09 pm by xl97 Reason: 1
Hey gang--
I am looking for an Eagle symbol for a 3-digit, 7-segment led display (the all-in-one units, not 3 individual 7-segments displays) :)
I am planning on use this with a a MAX7219/7221 chip, for reference during reading.
First..  I have to ask about the differences between these two displays I found:
1 has 12 pins:
http://www.ebay.com/itm/5pcs-0-56-inche-3-digit-led-display-7-seg-segment-Blue-common-Cathode-/140918781311?pt=LH_DefaultDomain_0&hash=item20cf69f57f
1 has 11 pins:  (which might make more sense?..to me I guess? SegA-G + DP = 8, 3 digits = 3GNDS = 11 pins total?)
http://www.ebay.com/itm/5pcs-0-36-inche-3-digit-led-display-7-seg-segment-Blue-common-Cathode-/140918781353?pt=LH_DefaultDomain_0&hash=item20cf69f5a9
I searched and searched.. and finally found a 3-digit, 7-segment display Eagle part/symbol..
but it has 12 pins..
SEGA-G + DP
C1
C2
C3 (which I'm assuming are the common grounds/cathodes?)
and then an "L" pin?
(possibly a LATCH pin perhaps?)
either way.. I dont believe is the one/type of display I want to use in the schematic as it doesnt match any of the actual/physical displays I have found/will be using?
Anybody have one? a link to a lib with one? Used one in a project before?
Also some insight on these differences?
again.. my current approach is to make a simple 'backpack' PCB (BOB) for this 3-digit display... with the MAX and vRegulator circuit(s) on the back....etc..  (this is to be used as a counter)
the MAX needs 3 lines to the Arduino.. and multiplexes so I don't need to worry about high power requirements
thanks again!
CrossRoads
You need a 3-digit display with 3 common cathode pins, 1 per digit.
I can't open those links - are either described as common cathode?
For example, browse the PDFs here, look for common cathode picture on first page.
http://www.kingbrightusa.com/category.asp?catalog%5Fname=LED&category%5Fname=KC3%2DDigit+7%2DSegment+Thru%2DHole+Display&Page=4&orderby=
xl97
yes.. those are common cathodes.. (at least by link & auction description)  :)
What is the difference between the 11 pin and the 12 pin?
(12 pin version Eagle symbol is was attached in .sch & .brd files above)
So in general.. I should just be looking for a normal (common cathode) 11 pin 3-digit display/unit..   right?
(I need to find an Eagle symbol now too!)  LOL
CrossRoads
xl97
#5
Aug 29, 2013, 04:42 pm Last Edit: Aug 29, 2013, 08:39 pm by xl97 Reason: 1
no worries..
just gave it the ol' bump in-case anyone else was around/had time.. :)  (or you forgot!)  ;)
thanks!
Im still abit confused as to the ebay links posted above??..
1 has an 11 pin pinout.. and the other seems to have 12?
11 makes sense for 3 digits (8) + 3 gnds = 11 pins..
I have a 'used' one at home.. (not sure where it came from.. looks to have the 12 pin bent down.. not used?.. its part of PIC based board..that has no relevance)  :)
so if I wanted to order some to play/work with... beside ensure they are common cathode....  does it matter?
The more important aspect is the Eagle footprint..
outside the one I posted above.. I found some in the
display-kingbright library...
under:  B?56-21*WA sub-directory...
SEEMS to be the style have in my hand.. and on Ebay..  12  pins..
however.. these are only 0.56inch in size?
I think the ones at my house I just measured were .75 in height (1.25 in width if I recall?)
anyone used a 3 digit numeric display before in there projects?
thanks!
xl97
Im curious if anyone can answer this:
when they are describing the 'size' of the 7-segments displays..  (like in the ebay links above)..
the .56in  are they referring to the actual NUMERIC height?.. or the overall height of the 'display/unit' itself?
the unit I have in hand.. measure .75in for the display in height.. but when I just measured the numeric portion.. it seems to be 0.56in?
(so I guess those 0.56in ones ARE the ones I need to order?  i cant seem to find them at Digikey or Mouser though?  tayada seems to only have 0.28in ones??)
CrossRoads
12th pin if it exists it's an unused pin on all the displays.
Quoted height is the actual segments, case adds to that dimension.
You can create a symbol for any size you want, I know you have in the past.
You can also check Newark.com for symbols, they have them for a lot of parts.
xl97
thanks!
so I know that I am looking for the 0.56" ones.. common cathode (blue)
(I think the symbol is already in one of the default libraries.. display-kingbright?)
but I'll check Newark anyways.. to see about ordering some :)
CrossRoads
Be careful with Newark orders, if they ship from UK it's expensive. Can download eagle symbols for free once you register with them.
xl97
thanks!..
heres the 99% completed pcb/schematic..
I wasnt 100% sure on the 'size/window' this needs to mount into...  so I designed it all to be as big as the display itself.. leaving freedom to make the outline/dimension layer as is needed with holes/cutouts..etc..
this is using 1206 components too.. I normally use 0603 stuff.. so this could could be smaller/cleaned up a bit I suppose...
feedback appreciated..
CrossRoads
1. You don't seem to have any layer 20 Dimension lines. Need those to determine board size.
I made these a little too tight, need a little taller so traces at top/bottom don't have manufacturing issues.
2. Once added, you will likely need to add a via & name it Gnd to get both polygons to connect to the Gnd plane.
You see can one at the left side.
xl97
1.) the pcb outline/shape (dimension layers) was left out on purpose..(as mentioned above) :) until I can measure tonight (physically) and determine the best size/shape...  (I think I'll have some drill holes on either side.. the pcb will be bigger than the whole display by maybe 0.25" or so.. so it'll literally be just an OUTLINE needed..since the whole circuit was contained the size of the display/unit)
2.) hmm.. this is where I can learn from you then...  I really only picked up the adding the polygon to both TOP/BOTTOM layers.. and then naming them GND form some articles/tutorials...etc...
and the only time I every use a VIA, is when I dropping a trace... and I click the mouse wheel to switch from top and bottom (auto adds a via) shortcut..
so adding one manually and how to get it to 'work' properly.. would be a nice lesson/tip!  a general lesson/idea on how to drop GND vias? the correct & easy way?  LOL
I tried to drop a via manually in the same location.. (and it added it to stage)
I went to NAME icon.. clicked on newly placed via.. named it GND...
gave me pop-up saying.. do I want to merge N$1 to GND?...etc.. I say yes..
then I get a new 'AIR-LINE' (UN-ROUTED LINE) on the board..??
CrossRoads
Click on via, click on the board,  hit escape.
Right click the via, Name it Gnd.
Very easy.
Connect the trace that appears, near the bottom left. No biggie.
