Topic: has anyone tried this? Sony ericsson arduino hack (Read 2364 times) previous topic - next topic
selwynberja
here is the video www.youtube.com/watch?v=5tHlJLQvE1Y
here is the code  http://www.kokoras.com/GSM/arduinogsm.htm
Code: [Select]
#include <SoftwareSerial.h> //Software Serial Port
#define RxD 7
#define TxD 8
#define pinOUT1 2
SoftwareSerial ericssonSerial(RxD,TxD);
String phonenum="XYXYXYXYXY";
String phonePDU="YXYXYXYXYX";
String OUT1ON="0C31D98C067A56A931D0D309";
String OUT1OFF="0D31D98C067A56A931D0D36804";
String OUT1FAIL="09CF2A35063206934C";
String OUT1ONOK="0ACF2A35067A3A41CF25";
String OUT1OFFOK="0BCF2A35067A1A8DA0E712";
pinMode(RxD, INPUT);
pinMode(TxD, OUTPUT);
pinMode(pinOUT1, OUTPUT);
ericssonSerial.begin(9600);
Init();
void Init(){
   while (send_command("AT&F",500) != "&F\r\r\nOK\r\n") {
   Serial.println("Modem reset...");
   while (send_command("ATE=0",500) != "E=0\r\r\nOK\r\n") {
   Serial.println("Echo Off...");
   while (send_command("AT+CLIP=1",500) != "\r\nOK\r\n") {
   Serial.println("Caller ID enabled...");
   while (send_command("AT+CPMS=\"ME\"",500).indexOf("CPMS")==0) {
   Serial.println("Phone Memory Selected for SMS...");
   while (send_command("AT+CNMI=,1",500) != "\r\nOK\r\n") {
   Serial.println("New SMS Indication Activated...");
   Serial.println("Ready...");
String send_command(String at_cmd, int dly){
  String msg;
  char incomingByte;
  ericssonSerial.println(at_cmd);
  delay(dly);
  while (ericssonSerial.available() > 0)
    incomingByte = (ericssonSerial.read());
    msg = msg + incomingByte;
  //delay(1000);
  return msg;
void sendSMS(String num,String txt){
  String pduTxt;
  int pduLength;
   pduTxt="0011000C9103"+num+"0000AA"+txt;
   pduLength=(pduTxt.length()-2)/2;
   //Serial.println(pduTxt);
   //Serial.println(pduLength);
   ericssonSerial.print("AT+CMGS="+String(pduLength)+"\r");
   delay(5000);
   ericssonSerial.print(pduTxt);
   delay(5000);
   ericssonSerial.write(26);
char recvChar;
String recvStr;
int ringCount=0;
String incSMS=0;
while(1){
   recvStr=0;
   while (ericssonSerial.available()>0){
     recvChar = ericssonSerial.read();
     recvStr=recvStr+recvChar;
     //Serial.print(recvChar);
   if (recvStr.indexOf("CLIP")>0){
     if (recvStr.indexOf(phonenum)>0) {
       Serial.println(phonenum+" is calling...");
       ringCount=ringCount+1;
       recvStr=0;
       //Serial.println(ringCount);
     }else{
        while (send_command("AT+CHUP",700) != "\r\nOK\r\n"){
        Serial.println("Unauthorized caller..");
   if (ringCount==2){
       digitalWrite(pinOUT1,HIGH);
       Serial.println("OUT1 ON...");
       //delay(5000);
       //digitalWrite(pinOUT1,LOW);
       //Serial.println("LED OFF...");
       ringCount=0;
       Serial.println("Sending SMS <OUT1 ON OK>.....");
       sendSMS(phonePDU, OUT1ONOK);
   if (recvStr.indexOf("CMTI")>0){
     Serial.println("SMS Received...");
     ericssonSerial.println("AT+CMGR=1");
     //delay(500);
   if (recvStr.indexOf(phonePDU)>0){
     //Serial.print(recvStr);
     if (recvStr.indexOf(OUT1ON)>0){
       ericssonSerial.println("AT+CMGD=1");
       sendSMS(phonePDU,OUT1ONOK);
     } else if (recvStr.indexOf(OUT1OFF)>0){
       Serial.println("OUT1 OFF...");
       Serial.println("Sending SMS <OUT1 OFF OK>.....");
       sendSMS(phonePDU,OUT1OFFOK);
         Serial.println("Invalid SMS...");
   if (recvStr.indexOf("CMGS")>0){
     Serial.println("Message Sent...");
   while (Serial.available()){
     recvChar = Serial.read();
     ericssonSerial.print(recvChar);
i have uploaded that sketch into my arduino, and i also  connected the rx and tx and correctly  but the problem is nothing appears on the serial monitor i have also tried  on hyper terminal  but still doesnt work =(.please help me
