Topic: why DOES this code work.. (Read 750 times) previous topic - next topic
eddiea6987
void sendString ( char *myString)
while (*myString> 0)
sendChar(*myString++);
when i send a string it displays it properly, but if i increment my string pointer from the get go it never sees index 0 which would be the first letter yet it does in fact display it ;
how so? is there a null character in beginning of my string?
the way i see is it like any array
"EDDIE"
0 1 2 3 4
E D D I E    <--see the E in the 0 position
but the very first operation in the while loop is *pointer++  so right there it goes to position one which is the first D...
im lost here :(
I could print the Arduino logo on a box of cereal and sell it as "Arduin-O's"
Henry_Best
"I could print the Arduino logo on a box of cereal and sell it as "Arduin-O's"
Cereal communication...
nickgammon
It's a post-increment, that's why. It wouldn't work if you wrote:
sendChar(*++myString);
holmes4
Post increment, i++, increments after the value has been used, pre increment increment before use.
So your code reads
sendChar(*myString);
                *myString++;
C++ means c incremented (improved) after use  :)
Mark
majenko
Let's break it down:
While the character is greater than 0:
- Print the character
- Increment the pointer
while (*myString++> 0)
See the subtle difference?  The ++ is performed after the test, *not* after each iteration of the while loop.  You could do it with a do...while loop though, and preincrement, as long as the first character is guaranteed NOT to be 0:
do {
} while (*(++myString) > 0);
majenko
Personally I thought it was a reference to the standardized language used in 1984 (George Orwell) - C that is double-plus good.
