Topic: Pro micro and Nrf2401+ SPI interface. (Read 987 times) previous topic - next topic
syphex
I have a pro micro without an SPI port that I would like to interface with an Nrf2401+ as a master.
This is the Nrf2401+
The pro micro pins are as follows:
SS_PIN 10
MISO_PIN 14
SCK_PIN 15
MOSI_PIN 16
So pin MISO pin on the pro micro goes to the MOSI pin on the Nrf2401+ and vica versa? Or is it the other way around?
SurferTim
#1
Sep 01, 2013, 07:34 am Last Edit: Sep 01, 2013, 07:37 am by SurferTim Reason: 1
The Arduino is the SPI master, and Nrf2401 is the SPI slave.
MOSI (Master Out - Slave In) goes to MOSI.
MISO (Master In - Slave Out) goes to MISO.
edit: Insure both devices work at the same voltage. If not, you may need a logic level converter.
pico
Actually, while Vcc to the nRF24L01+ must not exceed 3.6V, the data pins are 5V tolerant.
So it's fine to run the nRF24L01+ with 5V level pins from an Arduino, but you must ensure the Vcc doesn't exceed 3.6V.
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
