Topic: Arduino XM10 webcontrol (Read 845 times) previous topic - next topic
doctor_t
Hello guy,
after i read and try to understand how to use all this stuff together i m here to ask for your help
i do have at home several appliance working with x10 protocol (marmitek) and decieded to upgrade with a web interface using arduino and the xm10 module
i tryed several libraries and managed to make the xm10 module working with simple sketch of X10 example like this
Code: [Select]
// include the X10 library files:
#include <x10.h>
const int rxPin = 3;    // data receive pin
const int txPin = 4;    // data transmit pin
const int zcPin = 2;    // zero crossing pin
 // begin serial:
 x10.begin(rxPin, txPin, zcPin);
 // Turn off all lights:
 x10.beginTransmission(A);
 x10.write(ALL_UNITS_OFF);
 x10.endTransmission();
 // Turn on first module:
 x10.write(UNIT_1);
 x10.write(ON);
 // Turn off second module:
 x10.write(UNIT_2);
 x10.write(OFF);
 // Turn off first module:
 x10.write(UNIT_1);
 x10.write(OFF);
 // turn on second module:
 x10.write(UNIT_2);
 x10.write(ON);
then i found in net some sketch to have an web interface with my arduino and try to send command trough a web page but witought big success i used 2 different library, the classic x10.h and x10ex.h
i don't have very good experience in programming and can t understand where is my mistake
for x10.h i used this kind of command line
Code: [Select]
and x10ex.h i used this
Code: [Select]
myHouse.write(HOUSE_P, UNIT_1, 3);
doctor_t
this is a part of the sketch i used for my webinterface
Code: [Select]
void WEBloop()
  // listen for incoming clients
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          Serial.print(readString);
       if(readString.indexOf("L=1") > 0) {// lettura del valore se il LED si deve accendere
          // il led sarĂ  acceso
         x10.sendCommand( A, ON);
         x10.write(UNIT_12);
         x10.write(ON);
         x10.endTransmission();[/color]
          LEDON = true;
          Serial.print("ON pin ");
          Serial.println(outPin);
          //il led sarĂ  spento
          digitalWrite(outPin, LOW); //sengo il led
          LEDON = false;
          Serial.print("OFF pin ");
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
