Topic: Calculate the Root Mean Sqaure (Read 1 time) previous topic - next topic
pedrolopes746
hello,
I'm using the library (... \ Arduino \ hardware \ arduino \ sam \ system \ CMSIS \ CMSIS \ DSP_Lib \ Source \ StatisticsFunctions) to calculate the RMS value  of the elements in the input vector. but the value I get is 0.0.
code used:
Code: [Select]
#define ARM_MATH_CM3
#include <arm_math.h>
float32_t data[5] = {1, 2, 3, 4, 5};
float32_t *d = data;
float32_t *pResult;
arm_rms_f32(d, 5, pResult);
Serial.println(*pResult);
while(1){
Quote
output
0.0
pedrolopes746
after a detailed analysis found that the problem is in the following line of code library arm_rms_f32.c:
Code: [Select]
/ * Compute Rms and store the result in the destination * /
   arm_sqrt_f32 (sum / (float32_t) blockSize, pResult);
if we have:
Quote
    arm_sqrt_f32 (7.5 pResult);
    pResult = 2.74
if we have:
Quote
float32_t sum = 30
uint32_t blockSize = 4
  pResult = 0.0
any solution?
Palliser
Hello pedrolopes746,
Try this:
Code: [Select]
float32_t *pResult;
while(1){
void arm_rms_f32(
  float32_t * pSrc,
  uint32_t blockSize,
  float32_t * pResult)
  float32_t sum = 0.0f;                          /* Accumulator */
  float32_t in;                                  /* Tempoprary variable to store input value */
  uint32_t blkCnt;                               /* loop counter */
#ifndef ARM_MATH_CM0
  /* Run the below code for Cortex-M4 and Cortex-M3 */
  /* loop Unrolling */
  blkCnt = blockSize >> 2u;
  /* First part of the processing with loop unrolling.  Compute 4 outputs at a time.
   ** a second loop below computes the remaining 1 to 3 samples. */
  while(blkCnt > 0u)
    /* C = A[0] * A[0] + A[1] * A[1] + A[2] * A[2] + ... + A[blockSize-1] * A[blockSize-1] */
    /* Compute sum of the squares and then store the result in a temporary variable, sum  */
    in = *pSrc++;
    sum += in * in;
    in = *pSrc++;
    sum += in * in;
    in = *pSrc++;
    sum += in * in;
    in = *pSrc++;
    sum += in * in;
    /* Decrement the loop counter */
    blkCnt--;
  /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
   ** No loop unrolling is used. */
  blkCnt = blockSize % 0x4u;
#else
  /* Run the below code for Cortex-M0 */
  /* Loop over blockSize number of values */
  blkCnt = blockSize;
#endif /* #ifndef ARM_MATH_CM0 */
  while(blkCnt > 0u)
    /* Compute sum of the squares and then store the results in a temporary variable, sum  */
    in = *pSrc++;
    sum += in * in;
    blkCnt--;
  /* Compute Rms, store the result in the destination and print it */
  Serial.println(sqrt(sum / (float32_t) blockSize));
Output:
Quote
3.32
Regards!
pedrolopes746
