Topic: Problem with wifi shield (Read 3306 times) previous topic - next topic
Everlance
Hi all, i recently just got a new wifi shield. i mounted it onto the arduino uno r3 but it doesn't seem to be working. i tried running the scannetworks example code and it said cannot detect wifi shield. can anyone help me please?
Everlance
Hi all, i have already updated to the latest firmware. Still, "WiFi shield not present" when i run sketch ScanNetwork. Can any kind soul advice me please? Thank you... Using IDE 1.0.5 fyi...
Everlance
upzzz! Anyone solved this problem before? I really do need to get this working for a project. I am using uno r3 and my wifi shield model is R3. IDE 1.0.5. also tired with 1.0.3. same problem.
Everlance
Bumpz... Can anyone help me please!
fpga6
Where did you get the latest wifi shield firmware?  Did you load the firmware from the "hardware" folder that was created when you installed IDE 1.0.5?
Everlance
yes, I flashed the firmware from the hardware folder that was created when i installed ide 1.0.5... I am very sure the jumper wire near vin and A0 is not connected when i load the scannetwork script. Still, wifi shield not detected.
Everlance
Hi ale16289, thanks for responding. I have tried the following methods and the problem still exist. I usually use batchisp to update my firmware and it usually does it without any errors. Is is ok for you to send me the working version of the firmware (wifiHD & wifi_nld) of your wifi shield? Also, are you using an external power source or just powering using usb.
ale16289
#8
Sep 20, 2013, 09:31 pm Last Edit: Sep 20, 2013, 09:36 pm by ale16289 Reason: 1
sorry for the delay...try with this two file
ale16289
this is the second
Everlance
thank you so much ale16289, I'll try it out and get back to you.
cjdelphi
Does the shield even power up? lights come on (surface mounted LED's) ? lights flicking once connected to a router?
Everlance
@ale16289 - I tried flashing both firmwares but they didn't work. Could it be that my flashing method is wrong? I followed the instructions here http://arduino.cc/en/Hacking/WiFiShieldFirmwareUpgrading. Do I need an external power supply?
@cjdelphi - When I flash the wifi_dnld.elf the link led comes on for awhile before the data led turns on. Ran scannetwork sketch, 'wifi shield not present'. After flashing wifiHD.elf, totally no led on at all, same problem when running scannetwork.
btfdev
You might want to follow our notes on updating Wifi shield firmware.
http://www.binarytaskforce.com/Weblog/2013/09/21/arduino-wifi-firmware-update/
Good luck, Team BTF
ale16289
few days ago i posted in this conversesion one link that explain to you teh step to do for upgrade the firmware...here there is the link
http://www.dfrobot.com/community/how-to-upgrade-arduino-wifi-shield-firmware-on-windows.html.
