Topic: Arduino software on Mac: Menu bar is blank (Read 983 times) previous topic - next topic
mbrick
Sep 01, 2013, 02:21 pm Last Edit: Sep 01, 2013, 02:22 pm by mbrick Reason: 1
Hello,
Trying to get up and running with a new Arduino Uno R3.  When I launch the Arduino software on my Mac, the menu bar is blank so I cannot go to tools and select the port to be able to upload to it.  See the screenshot below.
Tried 1.0.5 and 1.5 beta.  Running OSX 10.9.  Updated Java to latest, Java test in Safari shows SE 7 update 25.
I can't even quit using CMD+Q, the menu is frozen it seems.  Have to use force quit.
Any ideas?
meerweten
you could try running a vurtual machine, wouldn't solve your problem but at least you can work (try ubuntu)
mbrick
I thought about that.  I have a Win 7 VM in VMware fusion but NO usb devices are working properly when i select them to pass through, appears a USB controller driver is not working based on device manager.  Can't find any helpful info, tried reinstalling the driver pack.
I'll try an Ubuntu VM and see if i can get that going.
meerweten
you need to pas throug the serial device not the usb device (depending on what vm software you use)
Running OSX 10.9.
OS X 10.9 (Mavericks)? The latest official release is 10.8.4.
I'm using OS X10.8.4 and Arduino IDE 1.0.5.
Arduino IDE 1.0.5 also works in a VM (VirtualBox 4.2.16, host OS: OS X, guest OS: Windows XP Professional, Service Pack 3).
If you can go back, try with OS X 10.8.4.
If you are indeed running 10.9, then this would be the culprit.  I was running it as well (developer) and didn't get the menu bar.  I rolled back to 10.8.5, and my menu bar for Arduino came right back.
.....now to learn Arduino.   :smiley-roll-sweat:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
