Topic: String to character formatting for SD logging. (Read 5101 times) previous topic - next topic
syphex
Sep 04, 2013, 05:03 am Last Edit: Sep 04, 2013, 05:07 am by syphex Reason: 1
I want to get the date string from my DS1307 RTC and use that as a file name, checking if one exists and creating it if not. So that it will create a new file every day.
I'm trying to use this to save and write to a file where the name of the file is a string File_name retrieved from the RTC clock. But it doesn't work
Code: [Select]
for(int i=1;;i++)
   String temp = File_name;
   temp.concat(i);
   temp.concat(".txt");
   char filename[temp.length()+1];
   temp.toCharArray(filename, sizeof(filename));
   if(!SD.exists(filename))
     File dataFile = SD.open(filename,FILE_WRITE);
   if (dataFile)
     dataFile.println(".");
     dataFile.close();
If I use
Code: [Select]
File dataFile = SD.open("Newfile.txt",FILE_WRITE);it creates the file, but doesn't write to it.
econjack
#1
Sep 04, 2013, 05:14 am Last Edit: Sep 04, 2013, 05:19 am by econjack Reason: 1
Sometimes errors become more obvious when you form the habit of formatting the source code correctly using Ctrl-T. In your code, you check to see if the file doesn't exist and, if it doesn't, you then define datafile and promptly execute the break statement, which transfers program control to whatever statement exists after the closing brace of the for loop. Therefore, nothing gets written to the file. It seems to me that you need to get rid of the break statement.
Also, try to compile the code and you'll find several other compile-time errors. Always try to get rid of those first. Why did you omit expression 2 in the for loop? If expression 2 (i.e., usually a relational test to see if another iteration of the loop is needed) is missing, it is logic True, which attempts to write an infinite number of data files. Why?
syphex
I didn't write the code I just copied it from somewhere, but I guess its just ment to loop until the filename array is full and then terminates with the break. Wouldn't it create a file name each time a character is concatenated? It seems a while loop would be better. It doesn't seem very efficient to say the least.
I didn't notice that the println was inside the for loop.
Im having trouble dealing with the variable scope. So the variables created inside the for loop are limited to that block of code? But I can't declare filename at setup because I don't know the length of it yet.
nickgammon
You are using the String class which can adjust the file name length dynamically, so that shouldn't matter.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
syphex
#4
Sep 04, 2013, 09:15 am Last Edit: Sep 04, 2013, 09:44 am by syphex Reason: 1
filename is a Char array. I don't understand what it does in this bit of code when in the loop?
Code: [Select]
Does it only break at the end? Isn't filename being concatenated every loop and therefore dataFile is pointing to new files all the time? But you can only open one file at a time right?
syphex
I just want to pass a variable into
Code: [Select]
myFile = SD.open(filename, FILE_WRITE) How can I convert a string into a char effectively? I tried to use
Code: [Select]
File myFile;
String temp="newfile.txt";
But that gives me: array bound is not an integer constant
nid69ita
Not possible, must be a constant value.
A value 40 I think is sufficient for a file name.
Code: [Select]
char filename[40];
my name is IGOR, not AIGOR
syphex
Ok I got it working using this before the setup():
Code: [Select]
File myFile;
String temp=("newfile");
And this inside the setup():
Code: [Select]
temp+=".txt";
myFile = SD.open(filename, FILE_WRITE);
But I need to do it during the loop, and it won't let me declare filename outside of the setup loop so I can't use it in the loop. Also my SD reader has no CD pin and I need to know when its in there and when someone takes it out is there anyway to do it??
PaulS
Quote
It won't? What the hell is it?
There is no "setup loop". There is a setup FUNCTION.
Where IS the code you are having problems with?
PaulS
By the way, do you really need the String crutch? The length of a file name on an SD card is limited (12 characters total). There is no reason to use a dynamically sizable construct to hold a fixed amount of data. Learn to use sprintf() and char arrays.
Finally, there is a world of difference between a string (a NULL terminated array of chars) and a String. The terms are NOT interchangeable.
syphex
#10
Sep 06, 2013, 03:55 am Last Edit: Sep 06, 2013, 04:14 am by syphex Reason: 1
Yeah your right, it doesn't really need to exceed 12 characters and I guess I don't need to use Stringobjects at all.
I have a question though, I want to be able to take the SD out while its still logging. But without a CD pin I can't tell it when to start writing to EEPROM, so I'll have to leave that out.
Now I want to write time in minutes for the day to the SD card only when the arduino is reset, so I can insert the SD card and restart to indicate to write to SD again. I need to organise it so that excel can detect it in a file for logging. I've been using comma delimiters so far. This is what I mean:
60, 20, 50
 , 20, 50
 , 20, 50
 , 20, 50
//SD card removed
//SD card inserted and arduino reset
120, 24, 45
 , 24, 45
 , 24, 45
Then Excel can add the new data to cell 120, and leave a gap between minute 60 and minute 120. Is there any better way to do this? How much memory does a blank space use? I guess a byte to store the character reference?
I calculate a 4gb SD card has enough memory for over a thousand years of 5 byte one minute logs... is this correct?
4GB = (((4294967296 bytes/5)/60)/24)/356 = 1675.6 years??
But excel has enough trouble loading the data as it is. Maybe I should log the seconds and use matlab instead? Or whats a program dedicated to graphing lots of log data?
PaulS
Quote
You REALLY should add a switch that defines whether to log to the SD card, or not. You should NOT remove the card when the switch is in the log position. Doing so can corrupt the file, if it is open when you remove the card. When the switch is flipped to the not-log position, you should close the file, if you keep it open.
Quote
Not even close. You are writing 5 byte-sized values as strings. A byte-sized value, like 100, can take 3 bytes to represent as a string ('1', '0', and '0'). Add a separator between strings and 5 bytes can use 19 characters. Plus the carriage return and line feed between records, and each record could be as many as 21 bytes, not 5.
zoomkat
Isn't a string an ordered set of bytes, and a "c-string" an ordered set of bytes saved to a memory location with a null terminator added to the end of the original string?
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
PaulS
Quote
It's an ordered set of bytes that is NULL terminated.
Quote
and a "c-string"
If we were discussing the differences between C and PHP and Java, I might feel compelled to clarify which language's string I was talking about. Since this forum is about the Arduino, which is programmed in C++, which is a superset of C, I don't feel it necessary to qualify the particular language's string I am talking about.
zoomkat
Quote
What ever floats your boat.  :)
