Topic: Help in serial communication (Read 9321 times) previous topic - next topic
sanketrege
Sep 05, 2013, 03:47 pm Last Edit: Sep 07, 2013, 01:32 pm by AWOL Reason: 1
Aim : send "hello" to Arduino. Arduino sends back "hi" if "hello" is received, else it sends "write hello"...via serial comm.
Code: [Select]
int x = 0;
char buffer[5];
char reply1[] = "hi";
char reply2[] = "write hello";
int i = 0;
if (Serial.available() > 0&&i<5)
buffer[i]=Serial.read();
i++;
if(i==5)
if(buffer[0]=='h'&&buffer[1]=='e'&&buffer[2]=='l'&&buffer[3]=='l'&&buffer[4]=='o')
Serial.write(reply1);
i=0;
Serial.write(reply2);
for (int x=0; x<5; x++)
buffer[x]='\0';
Serial.flush();
i=0;
This code works when i type hello in serial monitor window...but for other strings, it doesn't work.
I know the logic in the code is wrong somewhere...but can't figure it out. :(
Please HELP!!
Moderator edit: code tags.
Abhik
I checked your code by uploading it into my Arduino and the code seems to work pretty well. Can you describe your problem in detail; as simply saying "it doesn't work" explains noting about the problem.
I think limiting the length of your 'buffer' array may be a part of the problem that you are facing. Also, try to replace
Code: [Select]
    i++;
with a loop.
sanketrege
Hey Abhik!
Thanks,
You're right. I tried increasing the length of the buffer. I also added a longer pause to let the buffer fill completely. It worked!
