Topic: HELP WITH THE LIBRARY FFT (Read 1 time) previous topic - next topic
Hello world arduino
I'm in a project is to demonstrate and plot the spectral diagram of an analog signal and not to start.???? ..... =(
First of all I read about arduino Seller FFT and see that is the only option to apply, but my problem is, as I can use it and do not know how?? .... =(.
I would like some help or some examples of how to use and get the amplitude and phase of each analog signal with this program because I need to extract all the amplitudes and phases of all the harmonics existing one signal and calculate the THD.
Thank you thank you
A link to the library ?
What is your sketch ?
When you also post the question in another language, you could add a link to it.
Hi, I'm new to programming in arduino
This is the library:
I do not know how to use the code,
I want to acquire analog 6-channel, and the code provided below is valid for 6 analog channels:
  if (position >= FFT_N)
  capture[position] = ADC + zero;
  if (capture[position] == -1 || capture[position] == 1)
    capture[position] = 0;
void adcCalb(){
  Serial.println("Start to calc zero");
  long midl = 0;
  // get 2 meashurment at 2 sec
  // on ADC input must be NO SIGNAL!!!
  for (byte i = 0; i < 2; i++)
    position = 0;
    midl += capture[0];
  zero = -midl/2;
And I do not understand if the prescale is activated for all analog ports, or is necessary to activate for each port.
Thanks you
