Topic: [SOLVED] Email Orb not working (Read 14088 times) previous topic - next topic
sigilwig444
When you run your Orb code do you still get this message?
Quote
Failed to initialize ethernet!
And you don't get that message with any other ethernet dhcp example code like DhcpAddressPrinter?
When I run my orb code I now get this message:
"connecting...
connected
lost connection before data was read
inboxCount:0"
And no, DHCPAdressPrinter works fine. I now know that my IP Address is 192.168.1.1 :)
SurferTim
Show me what you replaced this malformed request with.
Code: [Select]
     client.print("GET ");
// missing the page you want here
// and stick to HTTP/1.0 below for now
      client.println(" HTTP/2.0");
      client.print("Host: ");
// missing your domain (server_name) here
      client.println();
Here is an example from my client code.
http://playground.arduino.cc/Code/WebClient
Code: [Select]
  if(client.connect(ipBuf,thisPort))
    Serial.println(F("connected"));
    sprintf(outBuf,"GET %s HTTP/1.1",page);
    client.println(outBuf);
    sprintf(outBuf,"Host: %s",serverName);
    client.println(F("Connection: close\r\n"));
    Serial.println(F("failed"));
    return 0;
PaulS
My output is in setup:
Code: [Select]
pinMode(LED_PIN, OUTPUT);
Does LED_PIN have a value of 10? No, it does not.
Regardless of whether you think you need to, or not, you MUST set pin 10 to OUTPUT. The default is INPUT for all pins. The example does set pin 10 to OUTPUT, and it works. Your code does not, and it doesn't work. See a pattern?
sigilwig444
Code: [Select]
Do you want me to set all of my pins to output or just 10 then???
sigilwig444
Code: [Select]
I tried setting pin 10 to output and it still says:
"connecting...
connected
inboxCount:0"
I'M STUCK UGHHH!!!!!
sigilwig444
Code: [Select]
      client.println();
Code: [Select]
    return 0;
This is what I replaced it with:
Code: [Select]
      client.print("GET phpmaster.comule.com");
      client.print("SCRIPT_PATH");
      client.println(" HTTP/1.0");
      client.print("Host: server48.000webhost.com");
      client.print("SERVER NAME");
      client.println("phpmaster.comule.com");
Now it says
"connecting...
connected"
and then about 10 seconds later it says:
"lost connection before data was read
inboxCount:0"...
sigilwig444
SurferTim
You are still using a malformed request. This should be good for your site.
Code: [Select]
      client.println("GET /checkGmail.php HTTP/1.1");
      client.println("Host: phpmaster.comule.com");
      client.println("Connection: close\r\n");
sigilwig444
Code: [Select]
Same thing:
Quote
connecting...
connection failed
inboxCount:0
connecting...
connected
inboxCount:0
Here's my current sketch:
Code: [Select]
  The "Email Orb": This is an internet-connected device
  that shows you how many new emails are waiting for
  you in your gmail account's inbox by pulsing an attached
  LED: one pulse per message.  If there are more than 10
  messages, the LED will remain on.
  This project requires an Ethernet Shield and an LED (with
  an appropriate resistor) connected to pin 9. It also requires
  a "proxy" php script to handle the https request to your
  gmail account and xml parsing.
  IMPORTANT: Read the comments below, as you will need
  to edit this file before compiling and uploading!
#include <SPI.h>
#include <Ethernet.h>
// set TEST_MODE = true to pulse LED 3x without
// making network connection to remote server.
// Handy for making sure your electronics work!
boolean TEST_MODE = false;
// BEFORE UPLOADING:
// You will need to set some of the configuration options below:
// Set your ethernet sheild's hardware address:
// Uncomment the line below and replace each "??" with the
// values from the sticker on your Ethernet Shield box.
byte mac[] = {  0x00, 0x11, 0x22, 0x33, 0x44, 0x55 };
// Uncomment the line below and replace the current
// value with IP address of the server you uploaded
// your PHP script to.  Note that the octets
// are sperated by commas, not periods.
IPAddress server(31,170,160,112);
IPAddress ip(31,170,160,112);
// Uncomment the line below and replace with the
// host name of your php server:
char server_name[] = "phpmaster.comule.com";
// path to your php script on the server:
char script_path[] = "/checkGmail.php";
// Some other config options (these defaults should be OK):
// interval between checking email (in millis):
unsigned long GET_INTERVAL = 1000 * 30;
// Affects rate of pulse:
int RAMP_DELAY = 3;
// LED output pin:
int LED_PIN = 9;
// end configuration options
// global variables:
long lastGet = 0 - GET_INTERVAL;
int inboxCount = 0;
EthernetClient client;
  pinMode(10, OUTPUT);
      Leave the Ethernet.begin(mac) statement below as-is if your network
      uses DHCP to assign IP addresses.  To assign a static IP address,
      use one of the following forms:
        Ethernet.begin(mac, ip);
        Ethernet.begin(mac, ip, dns);
        Ethernet.begin(mac, ip, dns, gateway);
        Ethernet.begin(mac, ip, dns, gateway, subnet);
     For more info:
       http://arduino.cc/en/Reference/EthernetBegin
    if (Ethernet.begin(mac) == 0) {
      Serial.println("Failed to initialize ethernet!");
      // Failed, so do nothing, forever:
      for(;;)
    // Allow Shield time to initialize:
  // Main loop: check for messages every GET_INTERVAL millis:
  unsigned long now = millis();
  if ( ( now - lastGet ) > GET_INTERVAL ) {
    lastGet = now;
    int result = getInboxCount();
    if ( result != -1 ) {
      inboxCount = result;
    Serial.print("inboxCount:");
    Serial.println(inboxCount);
  else {
    pulseInboxCount();
int getInboxCount() {
  if (TEST_MODE) {
    Serial.println("TEST MODE: returning dummy inbox count");
    return 3;
    Serial.println("connecting...");
    // if you get a connection, report back via serial:
    if (client.connect(server, 80)) {
      Serial.println("connected");
      // Make an HTTP request:
      client.print("GET /checkGmail.php HTTP/1.1");
      client.print("Host: phpmaster.comule.com");
      boolean weAreReadingTheNumber = false;
      // let's arbitrarily cap the number at 2 digits,
      // and initialize it with spaces:
      char inboxCountStr[] = {"  "};
      byte strPos = 0;
      int inboxCountInt;
      while(client.connected()) {
        if (client.available()) {
          char c = client.read();
          //Serial.print(c);
          if (weAreReadingTheNumber) {
            if ( c == ']') {
              inboxCountInt = atoi(inboxCountStr);
              client.stop();
              return(inboxCountInt);
            else if (strPos > 1) {
              Serial.println("WARNING: Exceeding allowed number of digits");
              client.stop();
              return 99; // use the max of 99 if more than 2 digits
            else {
              inboxCountStr[strPos++] = c;
          else {
            if ( c == '[' ) {
              weAreReadingTheNumber = true;
      Serial.println("lost connection before data was read");
      client.stop();
      return -1;
    else {
      // if you didn't get a connection to the server:
      Serial.println("connection failed");
      return -1;
void pulseInboxCount() {
  //Serial.print("pulse count:");
  //Serial.println(inboxCount);
  if (inboxCount < 10) {
    analogWrite(LED_PIN,0);
    for ( int i = 0 ; i < inboxCount ; i ++ ) {
      singlePulse();
    // ensure pin is off between sets of pulses:
  else { // if 10 ore greater, steady on:
    analogWrite(LED_PIN,255);
  delay(1000); // delay between sets of pulses
void singlePulse() {
  int v;
  // After some experimentaiton, I adjusted starting/ending
  // values of loops to create smoother sets of pulses.
  // Ramp brightness up:
  for ( v = 50 ; v < 256 ; v++ ) {
    analogWrite(LED_PIN,brightness(v));
    delay(RAMP_DELAY);
  // Ramp brightness down:
  for (v = 255 ; v > 50 ; v-- ) {
    analogWrite(LED_PIN,(int)brightness(v));
    delay(RAMP_DELAY);
Brightness function: this is used to translate a linear range of values
to something resembling an exponential curve.  This is useful because
humans perceive phenomena such as brightness logarthmically, not linearly.
The result is an LED that appears to pulse much more evenly.
int brightness(int input) {
  //return (int)(pow(input,4)*255.0);
  return (int)(pow((float)input / 255.0, 4) * 255.0);
SurferTim
#24
Sep 06, 2013, 09:46 pm Last Edit: Sep 06, 2013, 10:08 pm by SurferTim Reason: 1
Use only one Ethernet begin(). I recommend using the dhcp version, since it worked before.
Code: [Select]
   // comment out this
   // Ethernet.begin(mac, ip);
   // leave this
     for(;;)
If you are using a static ip, this will cause that fail:
Code: [Select]
Your localnet is 192.168.1.x.
edit: And if the dhcp server assigned you 192.168.1.1, then that is not the dns server or gateway ip. If you use a static assignment, you must specify all the other settings. Otherwise, 192.168.1.1 will be used for the dns server and the gateway, which it isn't.
sigilwig444
Code: [Select]
   // comment out this
   // leave this
     for(;;)
Code: [Select]
Still nothing...
SurferTim
I used the GET sketch code here
I used this as the server stuff
Code: [Select]
IPAddress server(31,170,162,43); // your ip
//Change to your domain name for virtual servers
char serverName[] = "phpmaster.comule.com";
The network settings are mine in the sketch. Change those to your network settings.
Then compile and upload. This is the result.
Quote
Starting ethernet...
192.168.2.2
Ready
connecting...connected
HTTP/1.1 200 OK
Date: Tue, 10 Sep 2013 18:22:07 GMT
Server: Apache
X-Powered-By: PHP/5.2.17
Content-Length: 159
Connection: close
Content-Type: text/html
[75]
<!-- Hosting24 Analytics Code -->
<script type="text/javascript" src="http://stats.hosting24.com/count.php"></script>
<!-- End Of Analytics Code -->
disconnecting.
Pass 1
It is downloading that page every 30 seconds right now.
SurferTim
#27
Sep 10, 2013, 09:45 pm Last Edit: Sep 10, 2013, 09:46 pm by SurferTim Reason: 1
Here it is. You must set the ip, gateway and subnet to your network settings.
Code: [Select]
  Web client sketch for IDE v1.0.1 and w5100/w5200
  Uses GET method.
  Posted October 2012 by SurferTim
  Last modified August 23, 2013
#include <SPI.h>
// this must be unique
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// change to your network settings
IPAddress ip(192,168,2,2);
IPAddress gateway(192, 168, 2, 1);
IPAddress subnet(255, 255, 255, 0);
// change to your server
// If no domain name, use the ip address above
// char serverName[] = "74.125.227.16";
// change to your server's port
int serverPort = 80;
int totalCount = 0;
int loopCount = 0;
char pageAdd[64];
 // disable SD SPI
 pinMode(4,OUTPUT);
 digitalWrite(4,HIGH);
 // Start ethernet
 Serial.println(F("Starting ethernet..."));
 Ethernet.begin(mac, ip, gateway, gateway, subnet);
 // If using dhcp, comment out the line above
 // and uncomment the next 2 lines
 // if(!Ethernet.begin(mac)) Serial.println(F("failed"));
 // else Serial.println(F("ok"));
 digitalWrite(10,HIGH);
 Serial.println(Ethernet.localIP());
 delay(2000);
 Serial.println(F("Ready"));
 if(loopCount < 30)
   // if loopCount is less than 30, just delay a second
   // every thirty seconds this runs
   loopCount = 0;
   // Modify next line to load different page
   // or pass values to server
   sprintf(pageAdd,"/",totalCount);
   // sprintf(pageAdd,"/arduino.php?test=%u",totalCount);
   if(!getPage(server,serverPort,pageAdd)) Serial.print(F("Fail "));
   else Serial.print(F("Pass "));
   totalCount++;
   Serial.println(totalCount,DEC);
 loopCount++;
byte getPage(IPAddress ipBuf,int thisPort, char *page)
 int inChar;
 char outBuf[128];
 Serial.print(F("connecting..."));
   return 0;
 // connectLoop controls the hardware fail timeout
 int connectLoop = 0;
   while(client.available())
     inChar = client.read();
     Serial.write(inChar);
     // set connectLoop to zero if a packet arrives
     connectLoop = 0;
   connectLoop++;
   // if more than 10000 milliseconds since the last packet
   if(connectLoop > 10000)
     // then close the connection from this end.
     Serial.println(F("Timeout"));
     client.stop();
   // this is a delay for the connectLoop timing
   delay(1);
 Serial.println(F("disconnecting."));
 // close client end
 client.stop();
 return 1;
It takes 30 seconds to start downloading the page. That gives you time to open the serial monitor without starting a download.
sigilwig444
Code: [Select]
  Uses GET method.
#include <SPI.h>
int totalCount = 0;
int loopCount = 0;
char pageAdd[64];
 // disable SD SPI
 pinMode(4,OUTPUT);
 // Start ethernet
 delay(2000);
 if(loopCount < 30)
   loopCount = 0;
   totalCount++;
 loopCount++;
 int inChar;
 char outBuf[128];
   return 0;
     connectLoop = 0;
   connectLoop++;
     client.stop();
   delay(1);
 // close client end
 client.stop();
 return 1;
Ok, so sorry for my last post for you to upload this code to the thread, I figured out what you meant. Here is my code of yours that I modified
Code: [Select]
   Uses GET method.
#include <SPI.h>
byte mac[] = {  0xBC, 0x18, 0x54, 0x67, 0x2B, 0x7E };
IPAddress ip(192,168,1,1);
IPAddress gateway(192, 168, 1, 1);
IPAddress server(31,170,160,112); // Google
int serverPort = 48;
int totalCount = 0;
int loopCount = 0;
char pageAdd[64];
  // disable SD SPI
  pinMode(4,OUTPUT);
  // Start ethernet
  //Ethernet.begin(mac, ip, gateway, gateway, subnet);
  delay(2000);
  if(loopCount < 30)
    loopCount = 0;
    totalCount++;
  loopCount++;
  int inChar;
  char outBuf[128];
    return 0;
      connectLoop = 0;
    connectLoop++;
      client.stop();
    delay(1);
  // close client end
  client.stop();
  return 1;
This is the message from the serial monitor I have been getting when I run the code:
Quote
ok
192.168.1.128
Ready
Connecting...Failed
Fail 1
Yes, I did modify the settings to my network.
SurferTim
These are not your correct network settings!
Code: [Select]
The ip and the gateway cannot be the same ip in this case. You should look in your router to get the settings. If you have challenges with this, maybe you should find an easier project and take a course on ip networks.
