Topic: If not working, whats misiing (Read 2055 times) previous topic - next topic
mrfunk
Hi I only want my gsm to send a text if "stereo" is not found in the buffer.
the LCD is working ok.
is it because my if and sms is not in the same curly brackets as the " stereo = Radio.stereo(buf);"
Code: [Select]
if (Radio.read_status(buf) == 1) {
          current_freq =  floor (Radio.frequency_available (buf) / 100000 + .5) / 10;
          signal_level = Radio.signal_level(buf);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.print(current_freq);
          lcd.setCursor(13,0);
          if (stereo) lcd.print(" ST ");
          else lcd.print("MO");
          lcd.setCursor(8,0);
          lcd.print(signal_level *  100 / 16);
          lcd.setCursor(11,0);
          lcd.print("%");
          //lcd.print("/15 " * 100 / 15));
          if((stereo)&&(smsmuteState == LOW))
           lcd.setCursor(12,1);
          lcd.print("OK"); }
        sms.beginSMS("phone number");
        lcd.clear();
        lcd.setCursor(0, 1);
        lcd.print(" SITE FAULT ! ");
        lcd.clear();
        lcd.print("SMS SENDING");
        sms.print("a\xFEgmail.com ");
        sms.print(Names[NameIndex]);
        sms.print("  ");
        sms.print(channel);
        sms.print(" SHUT DOWN");
        sms.endSMS();
        lcd.clear();
        lcd.print("SMS SENT OK");
        delay(5000);
        lcd.clear();
MarkT
Without seeing all the code its pure guesswork, but have you initialized stereo before the first if?
mrfunk
Here is my full slightly neater code.
I only want an sms when "stereo" and "smsmute==low"
At the moment it is ignoring the "stereo" bit.
Thanks
Code: [Select]
// libraries
#include <GSM.h>
#include <LiquidCrystal.h>
// //#include <Si4703_Breakout.h>
#include <Wire.h>
#include <TEA5767.h>
// from https://github.com/andykarpov/TEA5767
#include <Button.h>
// from http://arduino-info.wikispaces.com/HAL-LibrariesUpdates
// PIN Number
#define PINNUMBER ""
///////////////////////////////  GSM  //////////////////////
// initialize the library instance
GSM gsmAccess;     // include a 'true' parameter to enable debugging
GSM_SMS sms;
GSMVoiceCall vcs;
// Array to hold the number for the incoming call
char numtel[20];
////////////////////////////// TEA5767 /////////////////////
TEA5767 Radio;
double old_frequency;
double frequency;
int search_mode = 0;
int search_direction;
unsigned long last_pressed;
///////////////////////////// LCD //////////////////////////
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 9, 8);
// This section descibes button connection.
const int buttonPin = A0;
const int upbuttPin = A2;
const int downbuttPin = A3;
const int selectPin =  A1;
const int smsmutePin = 6;
///////////freq map//////////////////////
float Freq[][5] ={
    99.5, 89.9 , 91.4, 104.7, 93.6                      }
  ,//Aberdare
    98.3 , 88.7, 90.9, 93.1, 103.5                      }
  ,//Abergavenny
    99.5 , 89.9, 92.1, 94.3, 101.7                   }
  ,//Wenvoe
    98.6 , 89.0, 91.2, 93.4, 104.3                   }
  ,//Abertillery
    98.1 , 88.5, 90.7, 92.9, 104.0                   }
  ,//Blaenavon
    98.5 , 88.9, 91.1, 104.7, 93.3                    }
  ,//Brecon
    98.0 , 88.4, 90.6, 104.6, 92.8                    }
  ,//Carmel
    89.5 , 91.7, 93.9, 96.4, 0                    }
  ,//kvh
  ,//kvh
  ,//kvh
  ,//kvh
  ,//kvh
const int NUM_FREQS = sizeof Freq[0]/sizeof Freq[0][0];
// variables will change:
int buttonState = 0;
int upbuttState = 0;
int downbuttState = 0;
int selectbuttState = 0;
int smsmuteState = 0;
int select = 0;
float channel;
// Save data variables
String IMEI = "";
// serial monitor result messages
String errortext = "ERROR";
///////////////////////// NAME INDEX ////////////////////////////////
char * Names[] = {
  "Aberdare  ", "Abergavenny  ", "Wenvoe", "Abertillery", "Blaenavon", "Brecon", "Carmel" };
const int NAME_COUNT = sizeof Names / sizeof Names[0];
int NameIndex = 0;
    Wire.begin();
    Radio.init();
    //Radio.set_frequency(99.5);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  pinMode(upbuttPin, INPUT);
  pinMode(downbuttPin, INPUT);
  pinMode(selectPin, INPUT);
  pinMode(smsmutePin, INPUT);
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Receive Voice Call");
  /////////////////////// LCD BOOT  turn on display? ////////////////////
  lcd.begin(16, 2);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("FM Rover by DM");
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("--Please  Wait--");
  lcd.print("-GSM Connecting-");
  //////////////////////// START GSM networks scanner/////////////////////////
  // scannerNetworks.begin();
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      lcd.clear();
      lcd.setCursor(0, 0);
      lcd.print(" GSM  Connected");
      delay(5000);
      lcd.clear();
      Serial.println("Not connected !");
      lcd.clear();
      lcd.print("NO GSM !");
  vcs.hangCall();
  Serial.println("Waiting for a call");
  ///////////////// SELECT SITE NAME //////////////////////
  while(select==0){
    // read the state of the pushbutton value:
    upbuttState = digitalRead(upbuttPin);
    downbuttState = digitalRead(downbuttPin);
    selectbuttState = digitalRead(selectPin);
    // if it is, the upbuttState is HIGH:
    if (upbuttState == HIGH) {
      // increment name
      NameIndex = (NameIndex+1)%NAME_COUNT;
    } // Wrap around
    //if it is, the upbuttState is HIGH:
    if (downbuttState == HIGH) {
      // increment name
      NameIndex = (NameIndex-1)%NAME_COUNT;
      if (NameIndex < 0) {
        NameIndex=NAME_COUNT-1;
    } // Wrap around
    if (selectbuttState == HIGH){
      select=1;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("> ");
    lcd.setCursor(2,0);
    lcd.print (Names[NameIndex]);
    lcd.setCursor(0,1);
    lcd.print("Select Location ");
    lcd.clear();
      unsigned char buf[5];
      int stereo;
      int signal_level;
      double current_freq;
      unsigned long current_millis = millis();
      for(int i=0; i<NUM_FREQS; i++) {
        channel=Freq[NameIndex][i];
        Radio.set_frequency(channel);
        smsmuteState = digitalRead(smsmutePin);
        lcd.print(Names[NameIndex]);
        delay(10000);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(6,0);
          lcd.print("MHz");
          else lcd.print(" MO");
          lcd.setCursor(10,0);
          lcd.setCursor(12,0);
          lcd.print("%");
          if((stereo)&&(smsmuteState == HIGH))
            lcd.clear();
          lcd.setCursor(0,1);
          lcd.print("");
          if (smsmuteState == LOW)
            lcd.clear();
            lcd.print("----- FAULT ------");
            lcd.clear();
            sms.print("\xFEgmail.com ");
            sms.print("  ");
            sms.print(channel);
            sms.endSMS();
            lcd.clear();
            delay(5000);
            lcd.clear();
          if (smsmuteState == HIGH)
            lcd.setCursor(14, 1);
          lcd.print("M!");
          delay(5000);
          lcd.clear();
AWOL
Your problem may become clearer to you (and us) if you get rid of of all the useless braces, and apply the auto format tool.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
mrfunk
hows this
Code: [Select]
// libraries
#include <GSM.h>
#include <Wire.h>
#include <Button.h>
// PIN Number
GSM_SMS sms;
GSMVoiceCall vcs;
char numtel[20];
TEA5767 Radio;
double frequency;
float Freq[][5] ={
  ,//Aberdare
  ,//Abergavenny
  ,//Wenvoe
  ,//Abertillery
  ,//Blaenavon
  ,//Brecon
  ,//Carmel
  ,//kvh
  ,//kvh
  ,//kvh
  ,//kvh
  ,//kvh
int select = 0;
float channel;
String IMEI = "";
char * Names[] = {
int NameIndex = 0;
  Wire.begin();
  Radio.init();
  lcd.begin(16, 2);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.clear();
  lcd.setCursor(0,0);
  // connection state
  // Start GSM shield
  while(notConnected)
      lcd.clear();
      delay(5000);
      lcd.clear();
      lcd.clear();
  vcs.hangCall();
  while(select==0){
      // increment name
    } // Wrap around
      // increment name
    } // Wrap around
      select=1;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("> ");
    lcd.setCursor(2,0);
    lcd.setCursor(0,1);
    lcd.clear();
  //boolean stereo = true;
  int stereo;
  int signal_level;
    delay(2000);// allow time to tune
    lcd.clear();
      delay(1000); // allow time for buffer ?
      lcd.setCursor(0,0);
      lcd.setCursor(6,0);
      lcd.print("MHz");
      // if (stereo)
      stereo = true;
      lcd.print(" ST ");
      lcd.print(" MO");
    lcd.print("%");
    delay(10000);
    if ((stereo)&&(smsmuteState == HIGH))
      lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("");
    if(smsmuteState== LOW)
      sms.beginSMS("cccccccccc42");
      lcd.clear();
      lcd.clear();
      sms.print("cccccccc\xFEgmail.com ");
      sms.print("  ");
      sms.print(channel);
      sms.endSMS();
      lcd.clear();
      delay(5000);
      lcd.clear();
      lcd.print("M!");
      delay(5000);
      lcd.clear();
PaulS
Code: [Select]
  while(notConnected)
While statements should ALWAYS have curly braces, as should if and for statements.
You need to pick a style - the { goes on a new line (my preference) OR the { goes on the statement that introduces the block -  and CONSISTENTLY use that style. Do NOT use both styles in the same sketch.
Code: [Select]
  while(select==0){
Makes for some difficult to follow code.
Use spaces between the ) and the { if you insist on putting the { on the statement line.
This is not a good idea:
Code: [Select]
      lcd.clear();
This does the same thing, and is easier to understand.
Code: [Select]
      if(!stereo || smsmuteState == LOW
         lcd.clear();
Nothing here about stereo being true or false...
Code: [Select]
With all that out of the way, you really need to learn about function. If you has a function to send an SMS, you could just call that, and then we could look at the implementation, and determine if that code looked right for unconditionally sending an SMS.
Then, we could look at the conditional call to the function, and see if that looked right. Much simpler to understand and debug code that way. Not to mention much cleaner looking and much simpler to write.
tylernt
Quote
Code: [Select]
      lcd.clear();
I'm with you there...
Quote
Code: [Select]
         lcd.clear();
...and you lost me again. Shouldn't that be:
Code: [Select]
if(!stereo || smsmuteState == LOW)
  lcd.clear();
Quote
Agreed.
PaulS
Quote
Shouldn't that be
If there is only one statement to execute, the curly braces are optional. Recommended, but not required.
tylernt
Quote
Shouldn't that be
True. However I was thinking of the
Quote
BareMinimum:8: error: expected `)' before 'lcd'
message the compiler reports. :)
PaulS
Quote
Picky, fucking picky.
tylernt
Quote
Being a pedant is sometimes important.
PaulS
Quote
That made me laugh.
