Topic: 2 while loops in a program loop, both can be true, which runs first? (Read 1 time) previous topic - next topic
otispunkmeyer
So further to my trying to work out what the hell this code I have been given does, there is a main program loop and inside the loop there are 2 while loops.
the opening line of each is as follows:
Code: [Select]
while (interrupt_val_1==LOW&&interrupt_val_2==LOW){some code...}
Code: [Select]
while(total_elapsed_time<=max_total_time){some code....}
both these things can be true. i.e. the two interrupts can be LOW and the total elapsed time can be less than the max allowable time (which is 12 minutes I think going off what is in the definitions up top).
So, given they are both true, which happens first?
The while loops follow on from each other, but if say, we get to the end of the first loop and the interrupt conditions and time conditions are still met, does the program flow on to the next while loop? or does it go back round to repeat the first loop? or does it do loop 1, then loop 2, then go back to loop 1?
incidentally the next line of the second while loop is:
Code: [Select]
if (interrupt_val_1==HIGH||interrupt_val_2==HIGH){some more code...}
so if it did go, loop 1, loop 2, loop 1.... loop 2 will be incredibly quick as the above condition will not be met and so it would skip all the code.
AWOL
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
nickgammon
Things are done in order, however after saying that, I'm confused by your question.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
AmbiLobe
The first while loop goes first. If an interrupt happens, then that has priority over the while loop. After the first while loop is finished, the second while loop would go into action.
otispunkmeyer
Ok guys cheers
I dont think i can post the code as it is, it is part of work that is confidential. I think posting it would just raise even more confusing questions as well. I will try tidy it up and remove commenting that relates to confidentiality and I may post it.
I have not written it, and I am 95% sure that it is not the final code I am supposed to have. I believe that has been lost into the ether or has gone walkies on the personal computer of the person who wrote it (who has since apparently destroyed a lot of information on confidentiality grounds). So this is what I am left with. It is poorly commented and seems to have been modified from even older code that did the same thing, but with different hardware and as such variables have been re-used and mixed in with new variables and its all gotten a bit confusing.
I just needed to know how loops behave if there are two loops, (one after the other within the main program loop, which use two different conditions for their execution), and if those two conditions are concurrently true. If I am understand right, the first loop will go, then the second, then we go back to the first. I was just unclear on how, once its entered the first loop, how it can escape to run the second loop, while the condition for the first loop is still met. i.e. should it not leave the first loop only when the condition is no longer met?
My idea of a while loop is:
you enter the loop based on a condition being true.
You then stay in the loop until this condition is no longer true.
so if I have:
Code: [Select]
void loop(){
n=0;
while(n<6){
n++;
while(value_1==LOW&&value_2=LOW){ some code }
while(total_time <= max_allowable_time){some more code}
some further code to do after the while loops
which is the basic structure of what I have actually. I enter the first loop which goes round as long as n is less than 6. I then enter the second nested loop because my value_1 and value_2 are LOW. My question then is, does the program loop around in there until such time that one of the values is no longer LOW?
Now, lets us say that an event happened and my interrupts fire. This now means value_1 is HIGH. Assuming I am then kicked out of that loop upon returning to the program, I should enter the second loop which will run if total time taken so far is less than the allowable time I have defined. I then go in that loop and it loops round.
The problem I see is that, if value_1 goes back LOW, nothing will happen. I will be stuck in the second loop until the elapsed time breaches the maximum.
But then maybe that is the point. In trying to explain it here, I can see things starting make a bit more sense. It is a great insight into other peoples logic looking at how they write code!
RoyK
Quote
Correct. And if you aren't checking the elapsed time within the second while loop it will be stuck there forever unless it's changed within the interrupt routine and an interrupt occurs. That's the reason we ask to see all the code. Otherwise we are guessing.
PeterH
This is a fundamental question about how code executes, and you should be able to post a code example that demonstrates the issue you are asking about without requiring any confidentiality.
My guess is that you are thinking in terms of a declarative language - in fact, you're programming in C++ which is a procedural language.
nickgammon
For that matter write a small test program and see for yourself.
More info:
