Topic: WiiChuck Servo project with video! (Read 1 time) previous topic - next topic
irock91
Im working on this project for uni, pretty much im building this system which balances a 5mm ball bearing on a plate with video feedback from a webcam, so that it can be guided through a maze. The robotic section of the design uses 2 servos to control the angle of the plate in order to make the ball move around. Currently I have a Wii Nunchuck connected to it in order to test the dynamics of the system.
I used the WiiChuckClass here: http://playground.arduino.cc/Main/WiiChuckClass
as well as the built in servo class. The actual code is an adapted version of the serial example in the WiiChuckClass. The speed of the system can be changed by changing the #define JUMP.
This video shows the prototype im currently working on.
http://www.youtube.com/watch?v=KkKmV0IkgXU&list=HL1378540706&feature=mh_lolz
Here is the code:
#include <Servo.h>
#include <WiiChuck.h>
#include "Wire.h"
//#include "WiiChuckClass.h" //most likely its WiiChuck.h for the rest of us.
#define SPEED_DELAY 0
#define JUMP 5
#define TOL 10
WiiChuck chuck = WiiChuck();
Servo xServo, yServo;
int xPos = 0, yPos = 0;
int xJoy = 0, yJoy = 0;
boolean onX = false, onY = false;
void updateServo();
  //nunchuck_init();
  chuck.begin();
  chuck.update();
  //chuck.calibrateJoy();
  xServo.attach(9);
  yServo.attach(10);
  delay(20);
  chuck.update();
  xJoy = chuck.readJoyX()/2+90;
  Serial.print(xJoy);
    Serial.print(", ");
  yJoy = chuck.readJoyY()/2+90;
  Serial.print(yJoy);
    Serial.print(", ");
  if (chuck.buttonZ) {
     Serial.print("Z");
  } else  {
     Serial.print("-");
    Serial.print(", ");
//not a function//  if (chuck.buttonC()) {
  if (chuck.buttonC) {
     Serial.print("C");
  } else  {
     Serial.print("-");
    updateServo();
void updateServo() {
  if( (xJoy + TOL) > xPos > (xJoy - TOL) && (onX = false) ){
    onX = true;
    xPos = xJoy;
  } else if ((xJoy) > xPos) {
   onX = false;
   xPos += JUMP;
  } else if ((xJoy) < xPos) {
    onX = false;
    xPos -= JUMP;
  xServo.write(xPos);
  if( (yJoy+TOL) > yPos > (yJoy - TOL) ){
    onY = true;
    yPos = yJoy;
  } else if ((yJoy) > yPos) {
    onY = false;
   yPos += JUMP;
  } else if ((yJoy) < yPos) {
    onY = false;
    yPos -= JUMP;
  yServo.write(yPos);
  delay(SPEED_DELAY);
PaulS
Code: [Select]
delay(SPEED_DELAY);
Calling delay() with a value of 0 is really not a good idea. Most of the time, you can get away with it, but, once in a while, that call will actually take 49+ days to return. Your marble will be long gone by then.
neogeo124
your code gives me 'WiiChuck' was not declared in this scope
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
