Topic: Programming - Where do I start? (Read 6174 times) previous topic - next topic
First time poster here. Before I fire of my questions, just a brief about me. I am a retired electronics engineer of 40 years. Never had the need to get involved in programming so from that perspective a novice. Now have plenty of time on my hands and looking to fill some off that time.
I have been researching the Arduino platform and impressed with the concept. What I would like find is what is the defining programming reference how to manual? A manual that takes you from ground zero and explains programming concept, language, syntax, examples etc etc. would appreciate any guidance other users who have gone before to point me in the right direction.
Be interested in open comments on wether the Arduino is the best platform for a beginner? Is there other option I should be looking at before going Arduino? Are there any alternative platforms that might make more sense for someone like me to ease me into programming....PIC, Atmel ???
jack wp
I think your choice of the arduino to be the best for a beginner.
I don't know of a book. Since the internet/google, I have pretty much stopped reading paper.
Browse through the arduino web site (lots of info in here).
Use the example programs in the IDE.
Have you got an arduino board yet, and the IDE? Have you tried the blink example?
There are a few of us old retired guys on here. I will turn 65 in 3 months.
If you have questions, we are here to give advice. Welcome!
Hi Jack,
Thanks for the reply. Yes there is a plethora of info on the web ...probably too much for a beginner!  :smiley-eek:  I suppose what I was looking for is that must read that give you the aha moments...I will keep digging.
No I have not yet got an Arduino board and IDE yet. Still wanting to make sense of the programming side first, that said I will most be jumping in and getting my hands dirty soon. I see there is a starter kit that sells for around the $100 mark......is this a good starting point?
Good to know there a number of retires here......what do you do with your Arduino platform?
jack wp
I don't know about the starter kit. I buy my components individually (seems to be half the fun). A arduino board will be about $20 +-. You can run many of the example programs without any additional components (resistor, LED, cap, transistors, etc). Maybe you already have some of the additional components.
I use my board(s) to experiment with mostly. I have one setup outside for a night light control, and dog/duck feeder alarm. I keep wanting to add garden watering, but I procrastinate.
Join us.
Sep 09, 2013, 02:19 am Last Edit: Sep 09, 2013, 02:27 am by HazardsMind Reason: 1
If you have a RadioShack nearby, see if it sells Arduino kits. They come with a lot of great components and they are perfect to start with. The Arduino IDE has plenty of example scripts(codes) you can play with and get to learn the language.
Understanding and writing code, is actually quite easy. I always tell people to think aloud about what you want to do, then see what you have at your disposal.
I want my LED to turn ON for 5 seconds then OFF for 2 seconds, then repeat.
(I put it in quote tags to use the bold and color options)
byte LED = 13; //Declare what pin your LED is set to, in this case were going to use the onboard LED on pin 13
void setup() //You must have the setup function in your code. **What ever is in this function will only happen once when Arduino has power
 pinMode(LED, OUTPUT); //You want to control this LED with the Arduino, so you want the pin to be set as an OUTPUT
} //End of Setup function
void loop() //Again, this is a must have, even if you don't use it. This function will constantly loop when the Arduino has power
digitalWrite(LED, HIGH); //tell pin 13 to be set HIGH
delay(5000); //This function is in milliseconds, so 5000 milliseconds = 5 seconds.
digitalWrite(LED, LOW); //After the 5 second delay is done, this will turn the LED OFF
delay(2000); //a 2000 milliseconds = 2 second delay
//Once the 2 second delay is done, the loop will start over.
} //End of Loop function
My GitHub:
White breadboards for us old farts.
From one retired old fart EE to another the arduino is  a great and fun place to get started programming but I wouldn't be too formal about it. The language is a subset of C++ with a few oddities thrown in  to suit the platform.
I recommend you pick up one of the several books on arduino programming from Amazon and flick through them. At the same time, equip yourself with a starter kit containing an Arduino board, a breadboard & some wire and a few resistors, LEDs, switches etc then just dive in. You'll learn rapidly once you get the syntax down, make a bunch of mistakes, and have a blast.
As with most things KISS (keep it simple - you know) to start. Before long you'll have it down. Don't try to learn it all at once. There is a lot of reference material here. Check out the links at the top of the page - especially the playground.
Some beginning Arduino books concentrate on programming while others emphasize the hardware elements. Because I come from a software background, I tended to gravitate towards those that discussed the hardware. Given your background, look towards those that emphasize the software. So, how do you pick? First, most of the books on Amazon have a "Look Inside" feature that let's you read a small section of the book. I taught programming for over 25 years, including C, and the stumbling point for a lot of students is pointers. Therefore, "Look Inside" at the book's Tabel of Contents and then read the treatment of pointers 'cause, if they get that right, chances are pretty good they got the rest of it right, too.
The Arduino Uno is probably the best to start with. I don't know about the "starter kit". You are probably best off getting a Uno, and a handful of LEDs, switches and resistors.
The IDE (which you can download right now for free) has lots of example programs. To make a bit more sense of it I would Google "C++ tutorial" although a lot of them assume you have standard input and output (ie. a keyboard and screen).
I would start by getting a few LEDs to blink in sequence, and then perhaps making them do something different if you press a switch.
Make sure you read up about resistors and LEDs (eg. http://www.thebox.myzen.co.uk/Tutorial/LEDs.html ) and some tips about switches (and some simple code) are here:
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
I've been all over the map, since 1966.. started off in hardware repair, doing some assembly (plugboard on an IBM 6400, IBM 360, etc.), some higher level languages (Fortan was my first), and then in about 1996, ended up coding for a living, both high level in the PC, to control my assembly stuff (Mits, 65xxx, Atmel AVR, etc.). So now, retired, I ended up coding for fun (VB.Net mostly), and decided to get into Arduino a month or so ago. Picked up an Arduino Uno on eBay, from China (genuine one, I think), for about 12 bucks, some prototyping shields with stick-on plastic breadboards, and a few sensors (my current project is a cloud sensor using a Melexis IR temperature sensor). So here I am, fiddling with a low-level machine, using a high-level language. Things do come around, don't they?
Dive in. Don't be afraid to try things. You aren't likely to break anything, and if you do, it's not like you have to spend hundreds to get back into it. Check out the examples as well as the projects you can find all over the net. Above all, have fun.
Well, I suggest you reading this book " Beginning C for Arduino " by Jack Purdum. Obviously, the name tells you that it was written specifically for Arduino users. Though, there are lots of similarities between C++ and Arduino language. The book is written in a very simple and clear way that most people can understand as a beginner. Almost every concept is well demonstrated in this book.
To help you understand more about AVR, the heart of Arduinos, let take a look at "Embedded C Programming and the Atmel AVR ". The book is a concise handbook for you to get to know the function of registers. You can apply the same code to Arduino as well and creat more flexible functions for your board.
Good luck!
@trung_aero: Thanks for mentioning my book. I did so want to say something in my own post above, but felt kind of guilty about it...always better for someone else to say it. Thanks!
Hi Guys,
Thanks very much for the info and encouragement.
All is beginning to make sense, have spent most of the day doing google searches, watching You Tube tutorials etc. a ton of info is out there and here too of course.
So I will get an Arduino board to get my toe in the water, from the research I have come up with to date it seem the Arduino UNO Rev 3 might be a good starter level for a programming novice like myself? Is this a good level to enter?
I will be ordering the books mentioned as I believe good reference books are essential.
Thanks for you input and wisdom.
jack wp
I think you will be happy with the Arduino UNO Rev 3.
Given that you will obviously have no trouble with the electrical side of the house, consider doing some C/C++ tutorials before you combine it with the arduino. Once you have the core coding concepts down, it will be easy to add the arduino.
