Topic: Everything for time missing from avr-libc (Read 1 time) previous topic - next topic
ajk_
You may (or may not have) noticed that everything for time missing from avr-libc.
Who made this wonderful decision?
In any case, I have a complete compatible fix.
https://github.com/xxxajk/RTClib
It wasn't really rocket science to add it in, but why is something so fundamental missing?
What if, for example, I wanted to attach a telescope and have it controlled?
This is yet another one of those decisions that don't make any sense.
westfw
Presumably the avr-libc folks (who are different from the Arduino folks, BTW) didn't include the (posix) time functions because a bare avr doesn't have inherent RTC capabilities.
If I happen to need the phase of the moon, I'm sure I'll be happy to compile the 40+ files in your addition, vs the 1 file in the original jeelabs RTCLIB...
fat16lib
Quote
These files are being committed to a future version of avr-libc!    http://lists.nongnu.org/archive/html/avr-libc-commit/2013-03/msg00010.html
Much of the code is extremely inefficient on avr and better date algorithms were published over 100 years ago. Zeller's congruence was published in 1882.  Many of the classic data/time algorithms have efficient implementations on avr and other small processors and should be used in a time library.
Quote
This version is not very useful but moon_phase is simple and might work.  There is not good support for time zones and DST.  You need lat/long for many of the functions and there is no interface to set these.
The included version of RTClib is out of date and is not compatible with the JeeLabs version.
For example JeeLabs version:
Code: [Select]
class RTC_DS1307 {
public:
    static void begin() {}
This version:
Code: [Select]
class RTC_DS1307 {
public:
    static uint8_t begin(const DateTime& dt);
decep
I was very interested in the time functions (core C functions, that is).  However, they do not appear to be working very well.  I tried to use some of the standard functions like ctime and asctime functions to convert an epoch based time to human readable text, but was getting bogus results.
For instance, using the epoch for today, I was generating dates in the year 2043!
I was able to use [basically] the same code and compile against gcc to test my implementation of the functions and was getting the correct output in Linux.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
