Topic: USART1 SPI slave mode, does not transmit data on TX (Read 936 times) previous topic - next topic
darighi
Hello guys,
I need help to set the USART1 as SPI slave MODE3 and send a few bytes when I receive a byte on RX pin.
All must happen into the interrupt RX.
The RX interrupt works fine because into my RX handler I increment a variable every time it enter and when I print it on my display  I see that it increments, but when I send a byte, nothing comes out, and the TX pin PA13 is always low.
I tryed to switch the PIN PA13 as normal I/O, to see if the pin works fine, and it works fine.
I post my code:
my defines
Code: [Select]
#define USART_SPI_PORT_ENABLE REG_PIOA_PER //Pio Enable
#define USART_SPI_PORT_OER REG_PIOA_OER //Pio Output enable
#define USART_SPI_PORT_ODR REG_PIOA_ODR    //PIo Input enable
#define USART_SPI_PORT_OWER REG_PIOA_OWER //Pio Output Mask
#define USART_SPI_PORT_OWDR REG_PIOA_OWDR //Pio Unmask output
#define USART_SPI_PORT_PUER REG_PIOA_PUER //Pio Pull up setup
#define USART_SPI_PORT_PUDR REG_PIOA_PUDR //Pio remove Pull UP
#define USART_SPI_PORT_MDDR REG_PIOC_MDDR   //Pio disable open drain
#define USART_SPI_PORT_ODSR REG_PIOA_ODSR //Pio Register I/O
#define USART_SPI_PORT_PDSR REG_PIOA_PDSR   //Pio Status Register, used to read input
#define USART1_MOSI PIO_PA12 //input
#define USART1_MISO PIO_PA13 //output
#define USART1_SCK PIO_PA16 //input
#define USART1_SS PIO_PA15 //input
#define USART_SPI_SLAVE_COM USART1
#define USART_SPI_SLAVE_COM_IRQn USART1_IRQn
#define USART_SPI_SLAVE_COM_Handler USART1_Handler
#define USART_SPI_SLAVE_COM_IRQ_PRIORITY         7
My USART initializzation
Code: [Select]
const usart_spi_opt_t usart_spi_settings = {
.spi_mode =  SPI_MODE_3,
.char_length = US_MR_CHRL_8_BIT,
.channel_mode = US_MR_USART_MODE_SPI_SLAVE
void usart_spimode_init( void )
/* Set USART1 piins */
USART_SPI_PORT_ENABLE = ( USART1_MISO | USART1_MOSI | USART1_SCK | USART1_SS );
USART_SPI_PORT_OER = USART1_MISO ;
USART_SPI_PORT_ODR = (USART1_MOSI | USART1_SCK | USART1_SS);
USART_SPI_PORT_OWER = USART1_MISO ;
USART_SPI_PORT_OWDR = (USART1_MOSI | USART1_SCK | USART1_SS);
        USART_SPI_PORT_PUER = (USART1_MOSI | USART1_SCK | USART1_SS);
/*Enable clock to USART1*/
sysclk_enable_peripheral_clock(BOARD_ID_USART1);
sysclk_enable_peripheral_clock(PIOA);
/* Configure USART AS SPI SLAVE MODE 3, 8 BIT . */
usart_init_spi_slave(USART_SPI_SLAVE_COM, &usart_spi_settings);
/* enable rx and tx */
usart_enable_tx(USART_SPI_SLAVE_COM);
usart_enable_rx(USART_SPI_SLAVE_COM);
       /*enable usart1 interrupt*/
NVIC_DisableIRQ(USART_SPI_SLAVE_COM_IRQn);
NVIC_ClearPendingIRQ(USART_SPI_SLAVE_COM_IRQn);
NVIC_SetPriority(USART_SPI_SLAVE_COM_IRQn, USART_SPI_SLAVE_COM_IRQ_PRIORITY);
NVIC_EnableIRQ(USART_SPI_SLAVE_COM_IRQn);
/* USART Enable interrupt received BYTE */
usart_enable_interrupt(USART_SPI_SLAVE_COM, US_IER_RXRDY);
my My USART Handler
Code: [Select]
void USART1_Handler(void)
NVIC_DisableIRQ(USART_SPI_SLAVE_COM_IRQn);    // Diisable usart1 interrupt
count_debug += 1;
/*USED FOR DEBUG*/
REG_USART1_THR = 10;  //send a number
Thanks for your help
Davide
