Topic: Lcd Smartie on arduino (Read 4635 times) previous topic - next topic
mazur888
Sep 09, 2013, 06:53 pm Last Edit: Sep 09, 2013, 06:55 pm by mazur888 Reason: 1
hello everyone. I've done lcd smartie on arduino nano (atmega328) for my PC.
everything seems to be working fine until I open lcd smartie program. all I got is screen full of zeros.
every connection is ok.
tested with 2x16 and 4x20 lcd's with same result.
project is based on this one: http://waihung.net/lcd-smartie-through-arduino/
code is from here: http://www.milesburton.com/LCD_Smartie_Powered_By_Arduino_Liquid_Crystal_library
Had anyone problem like this?
thx
mazur888
thanks but this also doesn't work for me. this sketch gives me blank screen, however winamp is detected by arduino because RX led is on along with winamp.
examples like hello world etc. are working fine so i assume wiring is correct too.
hasaranga
#3
Oct 06, 2013, 04:58 am Last Edit: Oct 06, 2013, 05:02 am by hasaranga Reason: 1
Are you using 2x16 LCD ?
things to check:
    baud rate specified in "config.ini" file must match to baud rate in sketch.
    arduino must connected to pc before you run winamp.
     check your wiring with provided diagram.
mazur888
#4
Oct 10, 2013, 07:25 am Last Edit: Oct 10, 2013, 07:27 am by mazur888 Reason: 1
baud rate is 19200 same in config.ini and ssketch.
everything conected properly and arduino is connected before winamp.
20x4 and 16x2 gives the same results.
is it possible that arduino is faulty? if is faulty so why everything else is working fine hmm....
hasaranga
okay.. try this:
1. connect arduino to PC
2. run arduino IDE
3. load serial monitor
4. select baud rate with no line endings...
5. send j01b
6. it will display level bar style-2
7. send k
8. it will clear display
mazur888
nothing happens. when i send command as you said RX led flashes for half a second and there is nothing changes on the screen. probably thats why i cant connect to lcd smartie and winamp. another thing is i have to use arduino ide under ubuntu, windows gives me error.  Lcd proc doesnt show anything aswel.
mazur888
problem solved! ftdi chip seems to be faulty. arduino is now connected via modified prolific 2303 usb to ttl device. lcd smartie still doesn't work but winamp plugin from 2nd post is working fine.  :)
hasaranga
great  :)
can you post a photo of your spectrum analyzer?
mazur888
#9
Oct 14, 2013, 04:45 pm Last Edit: Oct 14, 2013, 05:27 pm by mazur888 Reason: 1
lcd smartie in my first post show just lcd full of zeroes, now i have screen full of threes.
pics of analyser
