Topic: 240x64 dots LCD display identification help (Read 977 times) previous topic - next topic
Tzeny
I have acquired an LCD made by Casil(part number CGM24064CBWF) but I can't find a user's manual so I was hoping you could help me figure out how to connect it to an Arduino UNO. For communication I'll be using the U8glib library. The LCD is powered by the T6964CFG microcontroller made by Toshiba.
Also, form what I know it may require a -10v input but I thought about using a PC power supply to get it running.
Pictures:
Thanks you for your help!
olikraus
Tzeny
I also believed that, but their model has 20 pins on the right side, mine has 22 and they all seem to be connected to other things.
olikraus
Quote
Why do you think so? From your picture it seems that 21 ands 22 are not connected to something.
Oliver
Tzeny
Unfortunately for me they are. It is a bit weird since all the models of LCD displays similar to mine only have 20.
olikraus
ok, agree... it was not that clear on the other pics.
You could look for the controller datasheet and try to trace the pins to the controller pins. With this approach you could at least figure out the digital input.
Oliver
Tzeny
I traced some of them back, but a couple have traces that go below the LCD's screen, so I can't trace those. I was thinking about pulling it apart(I have 2 more) and seeing exactly what goes where.
olikraus
Or measure the resistance between the module pin and the controller pin.
Oliver
Tzeny
To anyone following this topic, pin 21 is GND and pin 22 is + for the LCD display. They are linked to the A and K pins on the other side of the board(anode, cathode)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
