Topic: Compiling problem (Read 3802 times) previous topic - next topic
firewolf913
Hi this is my code :
Code: [Select]
#include <Servo.h>
Servo scanservo;
int lmf = 10;
int lmr = 9;
int rmf = 12;
int rmr = 13;
const int pingpin = 7;
const int scanservopin = 6;
const int turntime = 500;
const int turnaroundtime = 1000;
const int distancelimit = 7;
{pinMode(lmf,OUTPUT);
pinMode(lmr,OUTPUT);
pinMode(rmf,OUTPUT);
pinMode(rmr,OUTPUT);
scanservo.attach(scanservopin);
delay(2000);
{go();
int distance = ping();
if (distance < distancelimit){
  stopmotors();
  char turndirection = scan();
  switch (turndirection){
    case 'l':
    turnleft(turntime);
    case 'r':
    turnright(turntime);
    case 's':
    turnleft(turnaroundtime);
int ping(){
  long duration, inches, cm;
  pinMode(pingpin,OUTPUT);
  digitalWrite(pinpin,LOW);
  delayMicroseconds(2);
  digitalWrite(pingpin;HIGH);
  delayMicroseconds(5);
  digitalWrite(pingpin,LOW);
  pinMode(pingpin,INPUT);
  duration = pulseIn(pingpin,HIGH);
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimetres(duration);
void go(){
  digitalWrite(rmf,HIGH);
  digitalWrite(rmr,LOW);
  digitalWrite(lmf,HIGH);
  digitalWrite(lmr,LOW);
void turnleft(){
  digitalWrite(lmf,LOW);
  digitalWrite(lmr,HIGH);
void turnright(){
  digitalWrite(rmf,LOW);
digitalWrite(rmr,HIGH);
void stopmotors(){
char scan(){
  int leftscanval,centrescanval,rightscanval;
  char choice;
  scanservo.write(30);
  delay(300);
  leftscanval = ping();
  scanservo.write(150);
  rightscanval = ping();
  scanservo.write(88);
  centrescanval = ping();
  if (leftscanval>rightscanval&&leftscanval>centrescanval){
    choice = 'l';
  else if (rightscanval>leftscanval&&rightscanval>centrescanval){
  choice = 'r';
else {
  choice = 's';
long microsecondsToInches(long microseconds)
{return microseconds/74/2;
long microsecondsToCentimetres(long microseconds){
  return microseconds/29/2;
On compiling it shows :
Code: [Select]
"In function 'void loop()':
obstacle_avoiding_bot:7: error: too many arguments to function 'void turnleft()'"
Please help me regarding my
problem.
The code is for an Obstacle Avoiding Bot.
AWOL
#1
Sep 10, 2013, 12:21 pm Last Edit: Sep 10, 2013, 12:23 pm by AWOL Reason: 1
Quote
Code: [Select]
void turnleft(){
Code: [Select]
turnleft(turntime);
The function you defined expects no arguments, yet you supplied it with one.
One is more than none, so you get an error.
Code: [Select]
int ping(){
That looks like you've got one too many closing braces "}"
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
firewolf913
#2
Sep 10, 2013, 12:45 pm Last Edit: Sep 10, 2013, 12:47 pm by firewolf913 Reason: 1
Thanks,
I also get an error which sounds like this:
Code: [Select]
obstacle_avoiding_bot.ino: In function 'int ping()':
obstacle_avoiding_bot:42: error: expected initializer befoore 'pinMode'
AWOL
Quote
It either "is" or it "isn't" - it doesn't "sound like".
That looks like you've got one too many closing braces "}".
I mentioned this earlier.
Code: [Select]
int ping(){
  return pulseIn(pingpin,HIGH);
firewolf913
#4
Sep 10, 2013, 01:02 pm Last Edit: Sep 10, 2013, 01:15 pm by firewolf913 Reason: 1
OK,
sorry,
I have just one more error :
Code: [Select]
obstacle_avoiding_bot.ino: In function 'char scan()':
obstacle_avoiding_bot:109: error: a function-definition is not allowed here before '{' token
code :
Code: [Select]
 {return microseconds * 0.0133858 / 2;
AWOL
"scan" is missing at least one closing brace, I expect.
firewolf913
Code: [Select]
#include <Servo.h>
Servo scanservo;
int lmf = 10;
int lmr = 9;
int rmf = 12;
int rmr = 13;
const int distancelimit = 5;
delay(2000);
{go();
if (distance <= distancelimit){
  stopmotors();
    case 'l':
    turnleft;
    case 'r':
    turnright;
    case 's':
    turnaround;
int ping(){
  digitalWrite(pingpin,HIGH);
void go(){
void turnleft(){
  delay (500);
void turnright(){
delay (500);
void stopmotors(){
void turnaround(){
char scan(){
  char choice;
  delay(300);
    choice = 'l';
  choice = 'r';
else {
  choice = 's';
  return microseconds * 0.0343 / 2;
AWOL
#7
Sep 10, 2013, 01:40 pm Last Edit: Sep 10, 2013, 01:47 pm by AWOL Reason: 1
Code: [Select]
int ping(){
You've got a bit of a problem here; you've promised the compiler that you're going to return an "int", and then you don't do it.
Shame on you.
It still looks like "scan" is missing one or more closing braces.
Code: [Select]
Istheresomethingwrongwithyourspacekey?
firewolf913
