Topic: add number to long int (Read 2521 times) previous topic - next topic
smallpoul
Sep 10, 2013, 08:23 pm Last Edit: Sep 10, 2013, 08:30 pm by smallpoul Reason: 1
    all i want is to add a number before the code that the sensor send. here the code:
  Simple example for receiving
  http://code.google.com/p/rc-switch/
  Need help? http://forum.ardumote.com
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
long int sensorcode;
long int type_sensor = 1;
  mySwitch.enableReceive(0);  // Receiver on inerrupt 0 => that is pin #2
  Serial.println("No RF");
  if (mySwitch.available()) {
    int value = mySwitch.getReceivedValue();
    if (value == 0) {
      Serial.print("Unknown encoding");
      sensorcode = type_sensor , (mySwitch.getReceivedValue());
      Serial.println (sensorcode) ;
    delay(3000);
      Serial.println("No_rf");
    mySwitch.resetAvailable();
Probably very stupid but it only show 1 without the rest of the code
What i want is if code is 45454545 change it to 145454545
Thanks
Mic
Delta_G
What is this line supposed to do?  What's that comma supposed to mean?
Since type_sensor = 1, right now it is setting sensorcode to 1.  Which is what you say you see in the Serial Monitor.  So that looks like it is doing exactly what you told it to.
If you just want to add a 1 in front of 45454545, then try 45454545 + 100000000.  That equals 145454545 all day long in any language.
|| | ||| | || | ||  ~Woodstock
econjack
What is this line supposed to do:
KeithRB
Not quite, Delta_G.
The comma operator "A pair of expressions separated by a comma is evaluated left to right, and the type and value of the result are the type and value of the right operand." (From K&R)
So, sensorcode will equal (mySwitch.getReceivedValue()).
Delta_G
Not quite, Delta_G.
So it is.  I had that backwards.  I thought it kept the one on the left.
Still, it isn't doing any good for the OP.
|| | ||| | || | ||  ~Woodstock
smallpoul
The thing is that the code length is not always equal, so 1000000 + sensor code does not work, is there a function that i could use. It simple, all i want is to add 1 before the code to identify what kind of sensor is it.
1ChicagoDave
So, what Is the range of digits possible?
PaulS
What is going to happen when you have 10 of these sensors?
Printing "1," or "27, " before the sensor value makes more sense than trying to manipulate the sensor value.
1ChicagoDave
Nice catch. I totally missed the "identify" comment!  :smiley-red:
So just add this
Serial.print("1");
Before this
      Serial.println(sensorcode) ;
KeithRB
if (sv < 10) {
  sv = sv+10;
} else if (sv < 100) {
  sv = sv+100;
} else if (sv < 1000) {
  sv = sv+1000;
} else if (sv< 10000) {
  sv = sv + 1000000;
[\code]
holmes4
1000000 needs to be long or you will get all kinds of odd things happening.
Try the following.
  int i = 1000000;
  Serial.println(i);
  Serial.println(1000000);
Mark
