Topic: Need code to send block of data present in text file of sd card to arduino (Read 2338 times) previous topic - next topic
chinni4292
Hi.
   i need to do two works.
    1 Read a text file from sd card and send to arduino so that,  2. I can send those data to other arduino board which is a slave to first arduino
Code: [Select]
#include <SD.h>
#include <SPI.h>
char c[32];
int i = 0;
File file;
 Serial.begin(57600);    //Begin serial communication
 pinMode (10,OUTPUT);    //Set pin 53 as output for SD lib
 if (!SD.begin(9)){     //Check that SD card is initialized
   Serial.println("SD not initialized");
 else {
   Serial.println("SD initialized");
 file = SD.open("logdata.txt");  //Open file
 if(file) {
   Serial.println("File opened");
   while (file.available()>0) {
     c[i]=file.read();
     i=i+1;
   Serial.print(c);
 delay(100);
I need a code that transfers data from sd card to arduino
Thank you.
johnwasser
Unless your entire file is less than 32 characters long you should probably process the file one character at a time:
Code: [Select]
#include <SD.h>
#include <SPI.h>
File file;
  SPI.begin();
  if (!SD.begin(9)) {     //Check that SD card is initialized
    return;
  else {
  if(file) {
    while (file.available()) {
      char c = file.read();
      Serial.write(c);
      digitalWrite(SS, LOW);
      SPI.transfer(c);
      digitalWrite(SS, HIGH);
    Serial.println("File failed to open");
void loop() {}
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
ashritha
Thank you.
I think your code does my first half of my work...i really appreciate if u give any hint how to send data(which is read from text file) from sd card to arduino using spi.
johnwasser
That's this part:
Code: [Select]
      SPI.transfer(c);
ashritha
ok thanks
how to send this data to another arduino which is a slave
ashritha
Code: [Select]
#include <SD.h>
#include <SPI.h>
File file;
const int chipSelect = 10;  /*for arduino*/
const int ss = 9; /*for sdcard*/
  SPI.begin();
    return;
  else {
  if(file) {
      Serial.write(c);
      SPI.transfer(c);
digitalWrite(chipselect, HIGH);  // ensure SS stays high
  // Put SCK, MOSI, SS pins into output mode
  // also put SCK, MOSI into LOW state, and SS into HIGH state.
  // Then put SPI hardware into Master mode and turn SPI on
  SPI.begin ();
  delay (5000);  // 5 seconds delay to start logic analyser.
  char c;
  // enable Slave Select
  digitalWrite(chipselect, LOW);    // SS is pin 10
  // send test string
  for (const char * p = "h/n" ; c = *p; p++)
    SPI.transfer (c);
// disable Slave Select
// turn SPI hardware off
SPI.end ();
while (1);  //loop
is this correct?
PaulS
Quote
is this correct?
If it works, it is. If it doesn't it isn't. It isn't rocket science to tell the difference.
