Topic: Adding external LED's to TX & RX (Read 4996 times) previous topic - next topic
BigBenElectronics
I have a revised USB to serial mini adapter in an enclosed power box to a board to my arduino pro mini.
I thought it would be cool to connect mounted LED's (2 mm)to the TX and RX, can i run it off of the lines directly, or would I have to feed the signal to a transistor and LED, or is not powerful enough to do either. I noticed that the built on LED's connect to different pins of the adapter according to the schematics, what's up with that?
johnwasser
The ATmega8U2 processor used on the board had some spare pins so they used those to drive the LEDs.
You can probably use 1K resistors and LED connected directly between the RX/TX pins and Ground.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
CrossRoads
Yes, can run from the lines directly, use 1K or higher resistor so there is little load on the lines.
Measure them with no transfer occurring - if they sit at a high level, you may want to add an inverter so the LEDs only light up when a transfer is occurring.
The built-on LEDs are driven from IO pins on the USB/Serial chip.
ibanman555
Are you referring to the actual Tx Rx lines on Pin's 0 and 1 (on a MEGA2560 for example)?  Would powering an LED off of these lines cause interference to the serial data transfer, in either direction?
