Topic: Designing a shield for Arduino UNO that is compatible with the XBee shield (Read 1 time) previous topic - next topic
Sanman
Hello,
I am currently designing a shield that contains all my circuits and an accelerometer to run with my Arduino Uno board. However, I will also need to put an XBee shield on top of the shield I am designing (so the order is: bottom: Arduino Uno, middle: my PCB, top: XBee shield).
The XBee shield I am referring to is:
http://ie.farnell.com/arduino/a000021/zigbee-mod-xbee-with-out-rf-mod/dp/1848697?Ntt=ARDUINO+-+A000021
My problem: I can't really find exact information about which pins the XBee shield actually uses. I know that it plugs to digital pins 0-7 and analog pins A0 - A5, but which pins other than RX and TX will actually be used by the shield?
Thanks,
sm
PaulS
Quote
None. You need to supply power and ground, RX and TX. Jumpers or switches to select which pins are better than hardwiring the shield to use pins 0 and 1.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
