Topic: Electrical Help for a Push-pull solenoid (Read 5776 times) previous topic - next topic
Blu-Vector
Hi, i have a system with this kind of hitter :
http://www.adafruit.com/products/413
This hits a lever that should release a spring.
But it has not enough streanght to release the spring even adding some voltage.
So i build another system.
With few coil the system shoot really hard but generate a lot of heat. With more coil the system burned my npn transistor. Is there any kind of diod or "safe" to put in this system? Or i need a biggher transistor?
It's rated
60v , 8amp
Airsoft Video Projects: [url=http://arduino.cc/forum/index
retrolefty
It's rated
60v , 8amp
That will take a transistor rated for such a load, but you didn't state what transistor number you used. A logic level N-channel mosfet would be a good choice. Also you should wire a diode across the solenoid's terminals, cathode wired to the +12v side of the solenoid.
Lefty
Blu-Vector
#2
Sep 17, 2013, 09:01 pm Last Edit: Sep 17, 2013, 09:03 pm by Blu-Vector Reason: 1
the npn transistor is the bdx53C. Thks for the advice.
retrolefty
That would be a very marginal transistor to use as it's max rated current is 8 amps and that would only be met with proper heat sinking. Find a transistor with higher ratings.
Lefty
dc42
Darlington transistors like that one are #4 in my list of things not to use. See http://miscsolutions.wordpress.com/2011/10/16/five-things-i-never-use-in-arduino-projects/ for why. Use a logic level N-channel power mosfet instead, it will run much cooler. And connect a flyback diode in parallel with the solenoid as Lefty says.
Blu-Vector
Very interessing, i will try to use a IRF540N
retrolefty
Not a good choice as it's not a 'logic level' mosfet and thus can't work to it's full rated values with a 5vdc gate voltage applied which is all an arduino output pin can apply.
Lefty
Blu-Vector
Waht about this, is rated 30v , 25amp , logic level P channel.
TomGeorge
Hi, how often does the hitter have to operate and how long are you pulsing it to make it operate.
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
jackrae
#9
Oct 09, 2013, 10:10 am Last Edit: Oct 09, 2013, 10:14 am by jackrae Reason: 1
Trigger systems like you've made which use high current solenoids invariably do not use what I'll describe as "constant" supply current.  Generally the power to drive the solenoid comes from a charged capacitor which is switched into the circuit via the transistor (or better still a FET).  This is termed "capacitor discharge" powering.  This provides short duration high current, after which the current tails off the virtually zero.  The system is frequently used by model train enthusiasts to trigger point switching.  However their mode of triggering won't directly suit your application.   you will need to include the triggering FET between the system output and your coil (in effect the point control switch referred to in the explanation text.
See :  http://www.talkingelectronics.com/projects/CDU-2/CDU-2.html
Note that this text refers to using AC but the system works with DC as well.
Blu-Vector
I know the method of capacitor discharge but i have a really small compartment to insert electronics, otherwise i really dont need all that pushing power. Thanks for the link.
Tom... smiley
It gives a really hard punch so i think just one hit it's far sufficient, btw to be sure i can operate the solenoid just twice or three time with a delay of 2 sec or more, just to be sure, also operating the solenoid with a too fast trigghering or a "long push"  will cause the solenoid to heat up , and we dont want this to happen  :)
What about this mosfet it would be fine?
Waht about this, is rated 30v , 25amp , logic level P channel. ( sorry the link was missing in the last post )
http://www.onsemi.com/pub_link/Collateral/NTD25P03L-D.PDF
pwillard
It was recommended that you try:
What made you decide on P channel?  Your solution will become more complicated with that device.
cjdelphi
A p-channel aint so bad... inside your function
Void setstate(boolean state)
     state != state;
     digitalWrite(pin,state);
Wiring is a little different though.
dc42
    state != state;
The OP is running the solenoid from +12V, therefore if he uses a P-channel mosfet then he will need to level-shift the gate signal. Using an N-channel logic level mosfet is simpler.
cjdelphi
    state != state;
I was under the impression to switch on the P-channel, sinking it to gnd/LOW would switch it on?   Or the problem being switching it off!
Use an NPN transistor to switch the P-FET then?
