Topic: Electrical Help for a Push-pull solenoid (Read 5807 times) previous topic - next topic
dc42
I was under the impression to switch on the P-channel, sinking it to gnd/LOW would switch it on?   Or the problem being switching it off!
Use an NPN transistor to switch the P-FET then?
If the source of the p-channel mosfet is at +12V because it is switching 12V to a solenoid, then the gate also needs to be around +12V to keep the mosfet off. So yes, the problem is switching it off. An NPN transistor can indeed be used to drive the gate from the 5V Arduino output signal. But unless there is a reason to use high side switching, it is simpler to use a logic level n-channel mosfet.
Blu-Vector
It was just a price matter. The P channel was cheaper.
Airsoft Video Projects: [url=http://arduino.cc/forum/index
dc42
Then you are not looking at mosfets with similar specifications. N-channel mosfets are generally cheaper than similar P-channel mosfets.
Blu-Vector
So maybe i'm looking wrong, i pay 16€ shipped for a pack of 100 p-mosfets like those with -5v Vgs , 25amp, 30volt. I pay almost the double for thre N kind with same specifics.
I'm looking for Vgs 5v , not more not less. Almost 15amp , and obv at least 12v am i looking wrong? Could someone tell me the near-right specs? The resistence of the coil is 7ohm
Noob question alert:
If a Vgs mosfet is rated Vgs = (+/-) 10 , it means it will be activated by the range -10 , 0 / 0, +10 , or it need the min and max value of -10  / +10?
dc42
Can you link to the packs of mosfets? Or at least provide the part numbers? It may be that the P-channel ones are in SMD packages and the N-channel ones are in TO220, which tends to cost more.
If the resistance of the coil is 7 ohms and you are running them from 12V, then the steady state current will be less than 2A. The current may be higher while the solenoid is pulling in.
If the rating is +/-10V then you must never apply more than +10V or less than -10V to the gate. To see what voltage you need to turn the mosfet fully on reliably, look at the voltage(s) at which Rds(on) is specified.
jackrae
I think you'll find that the +/- is used to denote "approximately"  rather than "logic + and logic -"  -  but I might be wrong
When I was a student (more years ago than I care to remember) we used a "wiggly equals" sign to denote approximation ?
Blu-Vector
Maybe you are confusing with the "error" thing , but here is not 20 ?1 , it's just ?20.
In fact If you look here
http://it.rs-online.com/web/c/semiconduttori/discreti/transistor-mosfet/
You can find lot of transistors with 15v -5v value. So i think is intended the range. But i'm not sure actually.
This is the code of the mosfet:
NTD25P03LT4G it's not an SMD.
btw
The irfz44n is rated 55V , 49A, ?10 , Rds(on)  passed 2volts ( based on grapghic )
http://www.irf.com/product-info/datasheets/data/irfz44n.pdf
So it should fit my case right?
dc42
I think you will find that it is in the DPAK SMD package. See http://uk.farnell.com/on-semiconductor/ntd25p03lt4g/mosfet-p-ch-30v-25a-d-pak/dp/2101430?Ntt=NTD25P03LT4G and the datasheet that it links to. The datasheet shows the IPAK package as well, however the ordering information lists only versions in DPAK.
Blu-Vector
I used a TIP132 at the end, i found one in my scavage box, it's working good, the pushing system is working perfectly ;)
