Topic: [Library] SoftwareSerialTX - A transmit only version of SoftwareSerial (Read 2756 times) previous topic - next topic
int2str
SoftwareSerialTX
A new Arduino/avr library based on [New]SoftwareSerial. This library is transmit only, so it can be used with only one pin and does not use any timers/interrupts.
It also removes the "Stream" dependency, which makes the library much smaller. This makes this library suitable for smaller AVR micro-controllers like the ATTiny85 and reduces resource usage on all platforms.
This library is great for use with serial LCD displays or for simple 1-way debugging.
The header file is documented and an example is also included in the zip file.
robtillaart
Nice work, very useful e.g. for serial displays.
Still you should consider derive it from the print Class so the user gets access to functions as print(float, 3) etc.
(make it #ifdef configurable ?)
In another thread I replaced the magic numbers of soft serial with formulas allowing "all" baud rates. - http://forum.arduino.cc/index.php?topic=138497.0 -
should be possible here too. The added value is that you can easily adjust baud rates to mismatches in clocks or systems that have lots of interrupts.
In that same experiment I found out that baud rates above 70~80 KB were not reliable. Have you done any tests how stable your version is?
FInally, can we expect a stripped read-only serial too?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
int2str
#ifdef sound like a good idea.
I removed it since it's a big increase in program size and memory usage.
Without the Stream dependency, I could also add write(int) and write(float).
What do you think would be better?
Quote
I saw that thread and was intrigued.
Without knowing all the history of [New]SoftwareSerial, I'm not sure if the magic numbers weren't deliberate however. On an ATMega328p with internal oscillator, the magic numbers have proven remarkably accurate. I might try switching to your formula and running some tests.
Quote
Not at this time.
