Topic: New tutorial - Arduino and SIM900 GSM Modules (Read 60001 times) previous topic - next topic
tronixstuff
A few people have been asking how to use SIM900-based GSM shields, so here's a start:
http://tronixstuff.com/2013/09/18/tutorial-arduino-sim900-gsm-modules/
A couple of Arduino tutorials at http://tronixstuff.com/tutorials - My Arduino book - http://nostarch.com/arduino. Please don't ask for help via direct message - use the forum!
tronixstuff
And I've updated it with some more remote-control examples:
http://tronixstuff.com/2014/01/08/tutorial-arduino-and-sim900-gsm-modules/
GlomB
There has to be a better way of checking caller-id and the SMS content? Seems really awkward the way you do it now?
tronixstuff
You could store the incoming data into a string and then parse it.
method8
In something like this:
Code: [Select]
if (SIM900.available() > 0){
    c = SIM900.read();
    if (c != '\r') temp = temp + c;
     else {
        //do something with string temp
method8
I'm using tronixstuff's tutorial extensively and it is a life saver.
There's one thing I can't manage: Software Power On/Off. And sometimes the arduino resets (lose global variables) after an SMS is sent. I don't know what's going on.
I'm using this version: SIMCOM SIM900 Quad-band GSM GPRS Shield Development Board for Arduino/Iduino. Works perfectly. Just didn't manage to power on and that's something I really need unfortunately. Any help?
kathyelecfreaks
Arduino SIM900:  http://www.elecfreaks.com/store/gprsgsm-moduleefcom-pro-efcompro-p-450.html
ricky101
Hi John,
Thanks for your very good Sim900 tutorials , found them to be the best around.
Could not leave thanks on your site as not member of those feeds.
Would just like to ask you for some more practical voltage questions.
Those shields say feed with 5v  to produced the 3v3 via the regulator but the regulator is able to accept a higher input voltage, but due to its minimal pcb heatsink wondered how it would fair with a 9v or 12v dc input ?
Its use in my project is very low, just sending out an alarm status message as a rare event.
Also when measuring the shields current during a SMS I can only see a peak of 330ma on my slow DVM, though its said it can reach 2A peak.
Again, in your experience,  would a Wall pack rated at 1A with an extra 470uf by or on the shield be sufficient to deal with that short 2A peak draw ?
Thanks
shpatel6
i do not find library relatede this codes such as print , printin so anyone have that library ?
or any other codes detail ?
shpatel6
markmonkey
At last code that works :)
Do you know how i can get the Arduino GMS library to work with this SiMCOM SIM900 shield?
Or do you have a GPRS example?
stex07
I have a problem with my SIM900 module which do not take the signal, ie the green light will blink and does pause signal indicating that it has. Ah to be this as I solve this problem
stex07
dechronos
hey guys,
i have a project to make some security alarm, and i have plan on connected it with SIM900 where the alarm would active when it receive a call (i try to use a code from tronixstuff), when i combine the code for the alarm it doesn't work, may i have some example on how to do that please?
AlexTadeo
what can i do if i don't want to receive new sms message notifications when i'm reading the serial port???
