Topic: ArduinoADK AT45DB161d reading status 0x5B ?! (Read 801 times) previous topic - next topic
Rahul2047
Sep 18, 2013, 05:17 am Last Edit: Sep 20, 2013, 04:13 pm by Rahul2047 Reason: 1
I have worked on MEGA+FLASH earlier with UART3 as SPI which worked great using AVR Studio 5/6 without Arduino. I want to try it with Arduino.  :)
I am accessing flash using ADK via SPI ( Arduino SPI library ).
I also tried other libraries for the flash.
I started with my own.  :smiley-mr-green:
It reads status as 0xAD, the good one each time I read the status register only.
When start with read write. The status becomes 0x2D for a while as it is bg.
Now sometimes it gets stuck while read write and gives status as 0x5B  :smiley-eek-blue: which seems like a rotated right bit shifted value of 0xAD.
I couldn't find the problem yet. I am still working on it. Any pointer will be also do. If above info is not enough I will post the complete code here. Which I'll have to clean.  :P  :smiley-red:
Thanks.
Edit:
Code below:
Code: [Select]
// calling from loop
void ProblemNarrowDownTest()
  unsigned long address = (unsigned long)TrueRandom.random(0x1FFF0); // 0x00;//0x1DFFFE;
  // Tx memory to Buffer
  digitalWrite(slaveSelectPin,LOW);
  NOP4CYCLES
   SPI.transfer(0x53);
  SPI.transfer(address>>16);
  SPI.transfer(address>>8);
  SPI.transfer(address);
  //SPI.transfer(0x00); // dummy
  digitalWrite(slaveSelectPin,HIGH);
  NOP4CYCLES
unsigned long now = millis();
  while(!(ReadStatus() & 0x80) && ((millis()-now)<1000));            //monitor the status register, wait until busy-flag is high
  Serial.println(ReadStatus(),HEX);
  // Compare
  NOP4CYCLES
  SPI.transfer(0x60);
  NOP4CYCLES
  NOP4CYCLES
    now = millis();
  unsigned char statusReg = (ReadStatus() & 0x40);
  // Write
  NOP4CYCLES
    SPI.transfer(0x84);
  SPI.transfer('t');
  SPI.transfer('e');
  SPI.transfer('s');
  SPI.transfer('t');
  NOP4CYCLES
  NOP4CYCLES
//Buffer to main
  NOP4CYCLES
   SPI.transfer(0x83);//(0x88);//(0x83); // Buffer1
  NOP4CYCLES
  NOP4CYCLES
     now = millis();
  DEBUG_LINE
  // Put compare here:
  NOP4CYCLES
   SPI.transfer(0x60);
  NOP4CYCLES
  NOP4CYCLES
    now = millis();
  // transfer main to buffer
  NOP4CYCLES
   SPI.transfer(0x53);
  NOP4CYCLES
  now = millis();
/////////////////////For read
  // transfer memory to Buffer
  NOP4CYCLES
  SPI.transfer(0x53);
  NOP4CYCLES
   now = millis();
  // Compare
  NOP4CYCLES
  SPI.transfer(0x60);
  NOP4CYCLES
  NOP4CYCLES
    now = millis();
  // Read back
  NOP4CYCLES
  PI.transfer(0xD4);
  SPI.transfer(0x00); // dummy test
  int len =  0;//datasetLen;
  while(len<4)
   char dataSet = SPI.transfer(0x00);      //read byte and put it in AVR buffer pointed to by *BufferPt
    Serial.print(" ");
    Serial.print(dataSet);
    len++;
  NOP4CYCLES
With random addresses.
Am I making mistake in addressing?
Thanks
