Topic: questions about voltage regulator, how many and what capacitors ? (Read 1 time) previous topic - next topic
firashelou
hello guys,
i have this schematic of shift registers (attachment file), i need to know please which option of these 3 is the best to do for voltage regulator, because i will be feeding the circuit with a 12V lead acid battery 3A, so i must regulate the voltage to 5V for shift registers:
  1- 1 voltage regulator that will be feeding all the 6 registers
  2- 1 voltage regulator for every 2 shift registers
  3- 1 voltage regulator for every shift register
so which option of the 3 is the best and i need please to know what are the capacitors that i should use for the voltage regulator and how ? (if a schematic is provided that will be great)
Aiming for the unreachable !
Grumpy_Mike
Quote
Number 1
Quote
It depends on the specific number and manufacturer of the voltage regulator. If you look in the data sheet for the one you have it will tell you.
firashelou
#2
Sep 18, 2013, 02:28 pm Last Edit: Sep 18, 2013, 02:41 pm by firashelou Reason: 1
this is the datasheet in the attachment file, it says i should use 0.33uF on the input and 0.1uF on the output so is there any other option for the input because i dont have now the 0.33uF and it's hard to get for a while ?
and about the option number, it can take it without any problems ?
Runaway Pancake
it says i should use 0.33uF on the input and 0.1uF on the output so is there any other option for the input because i dont have now the 0.33uF...?
Three 0.1uF capacitors in parallel = 0.3uF = close enough.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Grumpy_Mike
Quote
Where?
Quote
That is normally a minimum, use any value greater than this.
firashelou
i am sorry i just added it
ok thanks guys i will see which option will be the best, greater or the parallel
firashelou
Grumpy_Mike
firashelou
1 uF capacitor will be fine ? or it's too much ?
No that will be fine.
ok i will consider this, but i put 4 capacitors of 0.1uF in parallel so i must get 0.4uF i guess should be good to go isnt it ?
Grumpy_Mike
firashelou
