Topic: Send a variable (Read 3458 times) previous topic - next topic
xhelioneto
hi everyone, i'm using a GPS Module + arduino uno + Shield GSM. I'm trying to send a variable for message using this example here:
#include "SIM900.h"
#include <SoftwareSerial.h>
//If not used, is better to exclude the HTTP library,
//for RAM saving.
//If your sketch reboots itself proprably you have finished,
//your memory available.
//#include "inetGSM.h"
//If you want to use the Arduino functions to manage SMS, uncomment the lines below.
#include "sms.h"
SMSGSM sms;
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to send and receive SMS.
int numdata;
boolean started=false;
char smsbuffer[160];
char n[20];
  //Serial connection.
  Serial.println("GSM Shield testing.");
  //Start configuration of shield with baudrate.
  //For http uses is raccomanded to use 4800 or slower.
  if (gsm.begin(2400)){
    Serial.println("\nstatus=READY");
    started=true;
  else Serial.println("\nstatus=IDLE");
  if(started){
    //Enable this two lines if you want to send an SMS.
    if (sms.SendSMS("xxxxxxx", "Test send sms"))
      Serial.println("\nSMS sent OK");
  if(started){
    //Read if there are messages on SIM card and print them.
    if(gsm.readSMS(smsbuffer, 160, n, 20))
      Serial.println(n);
      Serial.println(smsbuffer);
But, I don't know how to send a variable in place of text message. I've tried this in this line:
for this:
if (sms.SendSMS("xxxxxxx", var1))
note: var1 is my variable that read the latitude and longitude of GPS Module. Is a char var1[15];
This didn't work
Can you help me to send a variable in place of text message? If you have a better example to send sms and you think with your example you can send a variable, please show me!
My GSM Shield is this: http://imall.iteadstudio.com/im120417009.html
I don't know English very well. I'm sorry for my mistakes.
hugo007
Code: [Select]
for this:
Does the var1 correct terminated using '\0' ?
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
zainalfahmi
im facing the same problem.. is it possible to send variable in place of text message?
