Topic: SD card problems on Yun (Read 4779 times) previous topic - next topic
MikeChick
Just got my new Yun. Was able to get SD card working right off using the datalogger example. Confirmed that, if SD card was missing, error was written to console. Not sure what I've done to cause this but now missing card will not cause error to display. That is, with SD card out, sketch will run normally with no error(s) at all. With SD card in, sketch also writes to card successfully. How does the yun determine if there is a card present? Also, tried running the SD Card test (see example 2 below please) and get this error:
Arduino: 1.5.4 (Windows 7), Board: "Arduino Yún"
In file included from sketch_sep19a.ino:26:
C:\Program Files (x86)\Arduino\libraries\Bridge\src/FileIO.h:28: error: redefinition of 'class File'
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:26: error: previous definition of 'class File'
I really want/need to be able to confirm SD card is in place at start up. Thanks in advance for any help you can provide.
Mike
Code: [Select]
  SD card datalogger
This example shows how to log data from three analog sensors
to an SD card mounted on the Arduino Yún using the Bridge library.
The circuit:
* analog sensors on analog pins 0, 1 and 2
* SD card attached to SD card slot of the Arduino Yún
Prepare your SD card creating an empty folder in the SD root
named "arduino". This will ensure that the Yún will create a link
to the SD to the "/mnt/sd" path.
You can remove the SD card while the Linux and the
sketch are running but be careful not to remove it while
the system is writing to it.
created  24 Nov 2010
modified 9 Apr 2012
by Tom Igoe
adapted to the Yún Bridge library 20 Jun 2013
by Federico Vanzati
modified  21 Jun 2013
by Tom Igoe
This example code is in the public domain.
#include <FileIO.h>
  // Initialize the Bridge and the Serial
  Bridge.begin();
  FileSystem.begin();
  while(!Serial);  // wait for Serial port to connect.
  Serial.println("Filesystem datalogger\n");
void loop () {
  // make a string that start with a timestamp for assembling the data to log:
  String dataString;
  dataString += getTimeStamp();
  dataString += " = ";
  // read three sensors and append to the string:
  for (int analogPin = 0; analogPin < 3; analogPin++) {
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    if (analogPin < 2) {
      dataString += ",";  // separate the values with a comma
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  // The FileSystem card is mounted at the following "/mnt/FileSystema1"
  File dataFile = FileSystem.open("/mnt/sd/datalog.txt", FILE_APPEND);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
  delay(15000);
// This function return a string with the time stamp
String getTimeStamp() {
  String result;
  Process time;
  // date is a command line utility to get the date and the time
  // in different formats depending on the additional parameter
  time.begin("date");
  time.addParameter("+%D-%T");  // parameters: D for the complete date mm/dd/yy
                                //             T for the time hh:mm:ss
  time.run();  // run the command
  // read the output of the command
  while(time.available()>0) {
    char c = time.read();
    if(c != '\n')
      result += c;
  return result;
Code: [Select]
  SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
  * SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
Pin 4 used here for consistency with other Arduino examples
created  28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
// include the SD library:
#include <SD.h>
#include <Bridge.h>
#include <Console.h>
#include <FileIO.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = 4;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("\nInitializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
  pinMode(10, OUTPUT);     // change this to 53 on a mega
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card is inserted?");
    Serial.println("* Is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
   Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("\nCard type: ");
  switch(card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    return;
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("\nVolume type is FAT");
  Serial.println(volume.fatType(), DEC);
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize *= 512;                            // SD card blocks are always 512 bytes
  Serial.print("Volume size (bytes): ");
  Serial.println(volumesize);
  Serial.print("Volume size (Kbytes): ");
  volumesize /= 1024;
  Serial.print("Volume size (Mbytes): ");
  volumesize /= 1024;
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
MikeChick
Decided to take a different tack to get past the compiler (redefinition) issues. Got the code below to compile/run but card won't initialize successfully. I keep getting the "initialization failed!" error message written to the console. Any help regarding where to go from here would be appreciated.
Mike
Code: [Select]
  SD card basic file example
This example shows how to create and destroy an SD card file
The circuit:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created   Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <SD.h>
File myFile;
   while (!Serial) {
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  if (SD.exists("example.txt")) {
    Serial.println("example.txt exists.");
  else {
    Serial.println("example.txt doesn't exist.");
  // open a new file and immediately close it:
  Serial.println("Creating example.txt...");
  myFile = SD.open("example.txt", FILE_WRITE);
  myFile.close();
  // Check to see if the file exists:
  else {
  // delete the file:
  Serial.println("Removing example.txt...");
  SD.remove("example.txt");
  if (SD.exists("example.txt")){
  else {
  // nothing happens after setup finishes.
pito
Code: [Select]
  if (!SD.begin(4)) {
