Topic: Read and INT value in Labview (Read 1 time) previous topic - next topic
I am working on a proyect with a Ping))) Sensor, an arduino duemilanove and labview.
Right now I am stuck because the distance measurement from the ping))) is stored in a INT value, and I don't have any clue about how I can read this varible in Labview, in the Arduino I am loading the Lifa base file mixed with Ping))) sensor example that came with Arduino IDE that is working fine as I am still able to read the data trought Arduino IDE option Monitor Serial, in Labview I am using the examples to use with Arduino but I have none related experience with both softwares.
Most of the examples out there are about reading and analog pin and graph it in Labview but that doesn't work for me
Any help will be appreciated.
PS If you need me to upload any of the software or code I am able to do it so.
PS2 I apologize for my English as is not my native language
an int should be send as 2 bytes
Code: (sending site) [Select]
int value = ...
byte b1 = value / 256;
byte b2 = value % 256;
serial.write(b1);  // notice write iso print
on the receiving site you need to merge the 2 bytes again
Code: (receiving site) [Select]
int value = readbytefromserial() * 256;
value = value + readbytefromserial();
got the idea?
Rob Tillaart
