Topic: I2C DS1307 RTC Clock weird problem, aka "2165-165-165..." output (Read 17635 times) previous topic - next topic
Philgood
Sep 22, 2013, 01:15 am Last Edit: Sep 23, 2013, 11:59 pm by Philgood Reason: 1
Hi all,
I have a weird problem with a DS1307 I2C Clock module, I'm an Arduino newbie and I hope some specialists here can help
Here is a pic of the RTC if it can help:
I used the connections, the sample code and the library from this page:
http://www.dfrobot.com/wiki/index.php?title=Real_Time_Clock_Module_(DS1307)_(SKU:DFR0151)
Everything worked fine for a few hours...
Then the RTC started sending weird output like:
RTC date: 2165-165-165 Mo  time: 165:165:85
When this happens I can no longer set the clock, neither change the NVRAM content
After searching on the web I found the two main reasons for this problem can be a bad I2C connection or a battery overvoltage
My connections seems fine, so I checked the backup battery voltage and it measured at 3.94V ! In fact it is a LIR2032 3.6V rechargeable Li-ion battery.
I removed the battery and then the clock worked fine again !
Then I tried putting a CR2032 3V Lithium battery, and the same problem was back...
If I remove again this battery the clocks works fine again
So, I thought the problem came from the provided battery overvoltage, and I thought putting a 3V CR2032 battery would fix the issue, but sadly nope
Any idea where the problem comes from an how to fix it ?
Thanks in advance for your kind help
RobvdVeer
I read somewhere that sometimes the battery cell holder shorts somewhere, like the effects you describe. Check out if the pins of the holder are not bent.
Rob
http://www.simplicate.info
Philgood
#2
Sep 22, 2013, 08:07 pm Last Edit: Sep 23, 2013, 12:39 am by Philgood Reason: 1
Thanks RobvdVeer for the suggestion
I carefuly checked and it doesn't seems this can be the issue
Here is a close view of the battery holder:
EDIT:
I made some more tests:
- without the backup battery in the RTC, I set my clock to the correct date/time, then I put in place the LIR2032 battery, the clock keeps runnin fine:
I think this excludes any short/bad contact problem
- leaving the battery in place, I unplugged and plugged back my arduino, the glitch is back:
So it seems that the clock gets stuck when powered by the backup battery
Weird
RobvdVeer
Is the battery of the correct voltage?
What if you use the sample code that comes with arduino? Does that make a difference? I'm just guessing here.
Rob
Philgood
#4
Sep 23, 2013, 11:28 pm Last Edit: Sep 24, 2013, 12:06 am by Philgood Reason: 1
Thanks for these suggestions
Well, according to what I found on the web the battery correct voltage is 3 to 3.3V
The RTC came with a LIR2032, wich is a 3.6V rechargeable Li-Ion battery. And I measured it's voltage at 3.98V! Some people reported the same problem with a 3.6V battery, and they fixed it by putting a 3V battery. So I  thought I found the problem, but putting in a CR2032 battery which is a 3V battery doesn't fix the issue, so I'm really lost here
I don't think it could be a code problem, otherwise the clock wouldn't work at all. In fact after the last tests, we can say the clock gets stuck when (equiped with battery AND disconnected from +5V)
And the Arduino doesn't comes with the needed library (DS1307new.h)
RobvdVeer
Measure the battery when it's connected to a load, an i'm sure it'll drop below 3.98v.
I'm out of suggestions to be honest, either the 1307 is faulty, or something weird happens when synchronising, as it is not a battery issue as you say.
Did you try another unit?
Rob
Philgood
Well, I see no explanation either, I guess the unit is faulty.
I orderer two different DS3231 I2C Clocks (they are more accurate than the DS1307), this should fix my issue :p
Thanks RobvdVeer pour your kind help !
RobvdVeer
Ironicly i've just replaced my ds3231 break outboard by a ultra low-cost ds1302 dip ic, for testing purposes. Doesn't do i2c or spi, it has a horrible 3-wire interface, i don't know how accurate it is, but if it is acceptable, i can drop the i2c library from my project and have one less smd chip to worry about...
Rob
Philgood
haha that's quite funny ideed ^^
OJT_PHSLOVER
Thank you so much!! We finaly remove the 2165-165-165 output ect..
We simply remove the CMOS Battery with only 3.1V output and we tap the 3.3V on Arduino Uno to the pin 3 of the DS1307. By browsing same problem and here i merge it and work fine now..
MrRRR
EDIT:
Weird
hi. please check the -ve below the battery holder. Desolder the battery holder and then resolder again. i'm doing like that and my problem is solve.
Magicalrobot
This reply doesn't solve the original problem but it may provide some clues.
I also had this very same problem with the only lines of output being:
2165/165/165 165:165:85
I found that my I2c was plugged into the incorrect pins as different google images of pinouts show different pins for I2c on the Nano (it should be A4 and A5).
As I had read this thread in hope of an answer I thought I would add some results from a little bit of experimentation.
If either of these I2c pins are not connected on their correct pin it gives the same tell tale output of 2165/165/165 165:165:85
If there is no battery and you disconnect 5v it stops transmitting (obviously)
If there is no battery and you disconnect just Gnd it transmits an output of  2000/1/1 0:0:0
If you have no battery but 5v and Gnd are connected it works just fine!
radames
Having the same issue, just coping and past my answer to stackoverflow, please send me your thoughts?
up vote
0
down vote
Having the same problem here, it turns out that the DS3231 communication can get unsynchronised with the microcontroller due to different events. Seems like the cryptic output is coming from that, at least here debugging with a DS3231 connected to an ESP8266 Arduino.
Following the datasheet specification:
The I2C interface is accessible whenever either VCC or VBAT is at a valid level. If a microcontroller connected to the DS3231 resets because of a loss of VCC or other event, it is possible that the microcontroller and DS3231 I2C communications could become unsynchronized, e.g., the microcontroller resets while reading data from the DS3231. When the microcontroller resets, the DS3231 I2C interface may be placed into a known state by toggling SCL until SDA is observed to be at a high level. At that point the microcontroller should pull SDA low while SCL is high, generating a START condition.
And inspired on their official application note 3506
Using the ESP8266 and using their I2C implementation. You can get macros functions on how to access the SDA and SCL pins bitwise. Here is one implemented reset function based on the official example for the 8051.
Code: [Select]
#define SDA_LOW()   (GPES = (1 << SDA))
#define SDA_HIGH()  (GPEC = (1 << SDA))
#define SCL_LOW()   (GPES = (1 << SCL))
#define SCL_HIGH()  (GPEC = (1 << SCL))
#define SDA_READ()  ((GPI & (1 << SDA)) != 0)
void resetRTC() {
 pinMode(SDA, INPUT_PULLUP);
 pinMode(SCL, INPUT_PULLUP);
 do {
   SDA_HIGH();
   SCL_HIGH();
   if (SDA_READ()) {
     SDA_LOW();
     SDA_HIGH();
   SCL_LOW();
 } while (SDA_READ() == 0);
This is working fine and seems to solve the problem
A more simple solution would be calling Wire.status(), it also seems to work.
I'm not sure if for all cases. This method is doing checks for status and for one case it calls twi_write_start() which has some similarities with the function resetRTC() above.
In case you want to implement a similar function for that ATMEL Arduino you will need to look into the bitwise implementation to manipulate SDA and SCL on Arduino I2C core.
this is the same question on StackOverflow
caxlex
The solution to this problem is to use a non-rechargeable battery cr2032 and cut the track that connects the 5v power with the "battery".
Nick_Pyner
Not necessarily. The solution depends on what the problem is, which can be the result of several different power issues.
A newbie can encounter this by simply adding a 16x2 LCD display after having time on the serial monitor, thereby suggesting the villain is the LCD backlight. It isn't, it is simply the trigger, and the real villain is inadequate power from the PC USB socket. In this event, the real solution is to use a 9v wall wart, and DS1307 is entirely innocent.
