Topic: Capture people sitting on a bench (Read 4425 times) previous topic - next topic
HazardsMind
What about a few photoresistors or a strip of photoresistors? If the bench has gaps between the wood or plastic beams, you could tuck the photoresistor between them. If some one sits down, the photoresistor value will change indicating a person is there. And photoresistors are very small, so it should fit easily between the gaps.
I wouldn't put the photoresistors where the person actually sits down, but on the part where the persons back leans against the bench, this way if someone puts a bag down, the photoresistor wont get covered and no incorrect readings.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
1ChicagoDave
What about a handful of capacitive sensors under the bench? They can have a range into the tens of centimeters and should work through non conductive materials (e.g. wooden bench).
Grumpy_Mike
Capture people sitting on a bench?
Have a large metal clamp come out of either side of the back rest an grab them. Then have an ether spray to knock them out.
dc42
I was going to suggest dropping a large net.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
snusmumriken
I would go for the loosened plank + microswitch, hooked up to an Ardulog (www.hobbtronics.co.uk).  Very small (easily hidden under the plank), very cheap, very effective, not going to be triggered by birds or squirrels.
