Topic: how to get my data on xively?? (Read 2034 times) previous topic - next topic
megayachtengineer
what am i doing wrong here?
// include all Libraries needed:
#include <Process.h>
#include <Bridge.h>
#define APIKEY        "?????????????????????????????????????????????????????"                  // replace your pachube api key here
#define FEEDID        ??????????                   // replace your feed ID
#define USERAGENT     "????????"           // user agent is the project name
// set up net client info:
const unsigned long postingInterval = 60000;  //delay between updates to xively.com
unsigned long lastRequest = 0;      // when you last made a request
String dataString = "";
  // start serial port:
  Bridge.begin();
  while(!Serial);    // wait for Network Serial to open
  Serial.println("Xively client");
  // Do a first update immediately
  updateData();
  sendData();
  lastRequest = millis();
  // get a timestamp so you can calculate reading and sending intervals:
  long now = millis();
  // if the sending interval has passed since your
  // last connection, then connect again and send data:
  if (now - lastRequest >= postingInterval) {
    updateData();
    sendData();
    lastRequest = now;
void updateData() {
  // convert the readings to a String to send it:
  dataString = "Temperature,";
  dataString += random(10) + 20;
  // add pressure:
  dataString += "\nPressure,";
  dataString += random(5) + 100;
// this method makes a HTTP connection to the server:
void sendData() {
  // form the string for the API header parameter:
  String apiString = "X-ApiKey: ";
  apiString += APIKEY;
  // form the string for the URL parameter:
  String url = "https://api.xively.com/v2/feeds/";
  url += FEEDID;
  url += ".csv";
  // Send the HTTP PUT request
  // Is better to declare the Process here, so when the
  // sendData function finishes the resources are immediately
  // released. Declaring it global works too, BTW.
  Process xively;
  Serial.print("\n\nSending data... ");
  xively.begin("curl");
  xively.addParameter("-k");
  xively.addParameter("--request");
  xively.addParameter("PUT");
  xively.addParameter("--data");
  xively.addParameter(dataString);
  xively.addParameter("--header");
  xively.addParameter(apiString);
  xively.addParameter(url);
  xively.run();
  Serial.println("done!");
  // If there's incoming data from the net connection,
  // send it out the Serial:
  while (xively.available()>0) {
    char c = xively.read();
    Serial.write(c);
Thanks
