I'm going to make a Maxim MAX11040K talk with a Arduino Due. The MAX11040K Is a 4 channel, 24bit ADC... as such, when I want to read the data register, the response will be 96bits long... in fact, the response will be a variable amount of bytes depending on which register I read from it, which may be a small problem - but not too large I think.
The problem is, for each command, the Due Extended SPI tutorial page seems to expect that I will receive only one byte as a response instead of 12 bytes. Reading the MAX11040K data sheet, I just send the 8bit command once, and then I will get back anywhere from 1 to 12 bytes back. Since using SPI_CONTINUE with SPI.transfer() implies that the command is sent one more time, I don't think that's a solution. Any ideas?
EDIT: This is what I have so far:
#include <SPI.h>
#include "customtypes.h"
#define ADC_CS 22
#define DAC_CS 23
#define ADC_READ 1
#define ADC_WRITE 0
#define ADC_SAMPLING-INSTANT-CONTROL-REG 0x40 //32bit
#define ADC_DATARATE-CONTROL-REG 0x50 //16bit
#define ADC_CONFIGURE-REG 0x60 //8bit
#define ADC_DATA-REG 0x70 //24*4bit
//the following pin numbers may change at any time
SPI.begin(ADC_CS);
SPI.begin(DAC_CS);
SPI.setClockDivider(2); //runs it at 42MHz
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0, DAC_CS); // page 29
SPI.setDataMode(SPI_MODE2, ADC_CS); // page 16
void dac_talk(int cmd, int number){
if(number > 131071 || number < -131072){
Serial.println("Value outside 17bit range!");
dacSPIframe command;
command.bitfield.value = number;
command.bitfield.cmd = cmd;
SPI.transfer(DAC_CS,command.bytes[2],SPI_CONTINUE);
SPI.transfer(DAC_CS,command.bytes[1],SPI_CONTINUE);
SPI.transfer(DAC_CS,command.bytes[0]);
void adc_read(byte address, byte resultcontainer[]){
byte command;
// if you want to read, add 128
command = command+0x80;
Serial.print("Sending this command to ADC: ");
Serial.print(command,BIN);
Serial.print("\n");
SPI.transfer(ADC_CS,command);
