Topic: [solved] due extended SPI problem (Read 978 times) previous topic - next topic
MichaelBot
Sep 24, 2013, 10:02 am Last Edit: Sep 24, 2013, 09:57 pm by MichaelBot Reason: 1
I discovered a problem with the extended SPI library:
Using more than one begin(CS) of the three predefined pins (4, 10, 52),
completely stopps any SPI communication.
If end(CS) is used before an other begin(CS) with a different pin it works.
Not sure if this is the intended use?
I thought they can be used in parallel, as shown in the extended SPI reference.
IDE: nightly build for mac downloaded 23.sept
cmaglie
MichaelBot,
I'm looking into this, thanks for the bug report.
C.
cmaglie
MichaelBot,
maybe I've found a regression, may you check if replacing
libraries/SPI/arch/sam/SPI.cpp
libraries/SPI/arch/sam/SPI_Class.h
in you arduino installation, with the one attached to this post solves your issue?
C.
MichaelBot
#3
Sep 24, 2013, 09:26 pm Last Edit: Sep 24, 2013, 09:31 pm by MichaelBot Reason: 1
Hi Christian,
yep :) this solves the problem (saleae & hameg & me proved)
thanks for the fast response and fix !
kudos & gracie
cmaglie
And also pushed for 1.5.5:
https://github.com/arduino/Arduino/commit/b0dc3174225ff1fb7f86dbfbd63f38d27843cab1
hope this is the last bug in SPI class.  :|
Thank you!
C.
