Topic: 'High' voltage 7-seg LED interface (Read 6217 times) previous topic - next topic
Mr. Swarf
Glad to help  :) I would strongly suggest that you use common anode though, makes it much easier!
Count on it. Thank you.
M.S.
M.S.
Graynomad
I think the problem is that dp_bit is local and reset every time the function is called, try
static byte dp_bit = 0;
Actually using the ^= instead of != should work exactly the same because the DP bit in hour will always be 0 before the operation.
Rob Gray aka the GRAYnomad www.robgray.com
smartroad
Sorted the problem. It needed to be:
Code: [Select]
outputChar(character[hour] ^ dp_bit);
not ^=
I couldn't see why the next 10's minute digit was also being affected and why when I added the static to dp_bit it caused this weird 3 way random brightness flash. By using ^= put the result back into the byte held in the character[] the hour was using, which is why it actually flashed when static dp_bit wasn't used. As the 10's minute was using the same number, on the next run round it also had the DP switched on.
Using the ^ now only applies the result at the time the procedure is called :)
Many thanks for all your help!
Graynomad
Doh! + sound of hand slapping forehead  ::)
Well done, yes that would have had some interesting affects. It's the sort of dumb error I make all the time but normally it's in the code I'm working on and it's fixed 2 minutes later. Much harder debugging code with a 5-hour turn around.
smartroad
Quote
I know  ;D But thanks again!
Although now I feel guilty and have to look at the rest of my code to tidy it up :D Already cleaned the main loop, not sure why I had so many IF statements all doing the same thing!! And calling displayOut in every result?! Saved about 50 bytes i think.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
