Topic: Drive a 60 W Peltier with Arduino (Read 4460 times) previous topic - next topic
Sedeca
High People,
I thought I also make a post here specific for the problem I have at the moment next to my general project description.
ATM I need to figure out how to best control this Peltier. http://uk.rs-online.com/web/p/peltier-modules/4901395/
I am planning on using this powersource, but I am flexible on that.
http://uk.rs-online.com/web/p/embedded-switch-mode-power-supplies-smps/7002381/
I think I need an H Bridge as I want to use the peltier as heater and cooler.
However I am not sure which one exactly as there are lots of chips and boards and motor drivers out there.
project description:
http://forum.arduino.cc/index.php?topic=189913.0
Thx for the help guys!
Sven
drewdavis
This one would work.
http://www.robotmarketplace.com/products/0-PL755.html
And this one.
http://www.robotshop.com/pololu-high-current-motor-driver.html
Just remember that you will need a way to remove the heat from the hot side when your using the cooler because it will quickly stop being cold as the heat cancels out the affect if it has no wear to go!
Erdin
Are you sure it is a 15V peltier element ?
Are you sure it can be reversed by reverse polarity ?
You should test it first. Perhaps you can try it with 5V so it won't get too hot.
As Drew Davis wrote, the hot side needs a heatsink.
An H-bridge can be used, but also a relay.
drewdavis
Quote
Not if you need to be able to make one side both hot and cold.
I have used many pelter elements and all have been reversible by switching the polarity. Thats not to say some can't be reversed, I just haven't had that experience. I do agree that it should be first tested.  If you have a variable power supply you could start at a low voltage like Erdin suggested and slowly bring up the voltage while monitoring how much current your using.
Best of luck!
tylernt
Quote
Two SPDT relays can be used to make an H-bridge.
drewdavis
Quote
yes, but not a relay.
tylernt
Quote
Technically a single DPDT relay could be used to apply both polarities... you just wouldn't be able to shut it off. ;)
Sedeca
I am not worried about cooling the hot side too much. I will have a rather large copper block on the "hot side".
I am only interested in a postive temperature gradient  (heating of 1 degree per second or so ). So it is running in a heating mode most of the time, where it is activly pumping heat out of the copper block (into the  sampleplate) and only if the heater wood overshoot I would need to cool a bit, so then I will always have a rather large cold reservoir (the copper block). the actual cooling down to 77 K will be done by liquid nitrogen :)
I was wondering if anybody has experience with using an old computer psu for testing purposes?
Or knows where I can find info on that. that would save some money in the initial tests. I would want something like 12 V, 6A.
Erdin
Heating without overshoot ? What about a simple heater ?
Perhaps a PID to prevent overshoot.
A PSU from a PC can be used.
Some old ones requires a small load, so you have to check the output voltages without load.
There is a sense wire, and you have to connect it to something.
http://reprap.org/wiki/PCPowerSupply
I have such a prepared PSU and it's very handy to have.
drjiohnsmith
sounds great fun
remember you are pumping 60 watts of heat into the thing,
   which you have to get rid off as well,
TomGeorge
#10
Oct 01, 2013, 11:39 am Last Edit: Oct 01, 2013, 11:51 am by TomGeorge Reason: 1
Hi, have you typed,  peltier   into the search box at the top of this page?
also look at this thread from another forum.
http://forum.allaboutcircuits.com/showthread.php?t=73374
The peltier devices have some power charactersitics that need the output from the PWM filtered to minimise losses.
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
Sedeca
HI Tom,
I have read some of the peltier threads but surely not all.
thank you for the input on the pwm atenuation. I was planning on putting in a simple low pass filter, with a resistor in series and a capacitor in parallel to the peltier. However I have not yet looked into the specifics. do you have any experience on that part of the story and can make suggestions?
Cheers Sven
Sedeca
actually on second thought I don't think that PWM needs to be filtered as long as the power suply doesnt exxed the maxium ratings of the peltier and the PWM cycle is fast...
see point 41 here:
http://www.tellurex.com/technology/peltier-faq.php
dc42
That's no good, you will waste a huge amount of power in the resistor. You need a series inductor (capable of handling the maximum Peltier current without saturating or overheating) and a Schottky flyback diode. You will need to increase the PWM frequency in order that you can use a low enough inductance (otherwise the inductor would be huge), and because of that you will probably need to use a mosfet driver chip (e.g. MCP1407) to make the mosfet switch fast enough.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
