Topic: Programming problem (Read 966 times) previous topic - next topic
ypyp3399
I have a question about the arduino due connect SD card ,use it to play music but Not read SD card ?
What is my sd card pin for errors or circuit fault?
I made reference to these siteshttp://arduino.cc/en/Tutorial/SimpleAudioPlayer
my Serial monitor show"Initializing SD card... failed! error opening test.wav"
My DUE pin connector SD card using ICSP-1, ICSP-3, ICSP-4 and pwm-4
my Program
Code: [Select]
Demonstrates the use of the Audio library for the Arduino Due
Hardware required :
*Arduino shield with a SD card on CS 4 (the Ethernet sheild will work)
*Speaker attched to ground and DAC0
Original by Massimo Banzi September 20, 2012
Modified by Scott Fitzgerald October 19, 2012
#include <SD.h>
#include <SPI.h>
#include <Audio.h>
  // debug output at 9600 baud
  // setup SD-card
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println(" failed!");
    return;
  Serial.println(" done.");
  // hi-speed SPI transfers
  SPI.setClockDivider(4);
  // 44100 Hz stereo => 88200 sample rate
  // 100 mSec of prebuffering.
  Audio.begin(88200, 100);
  int count=0;
  // open wave file from sdcard
  File myFile = SD.open("test.wav");
  if (!myFile) {
    // if the file didn't open, print an error and stop
    Serial.println("error opening test.wav");
    while (true);
  const int S=1024; // Number of samples to read in block
  short buffer[S];
  Serial.print("Playing");
  // until the file is not finished
  while (myFile.available()) {
    // read from the file into buffer
    myFile.read(buffer, sizeof(buffer));
    // Prepare samples
    int volume = 1023;
    Audio.prepare(buffer, S, volume);
    // Feed samples to audio
    Audio.write(buffer, S);
    // Every 100 block print a '.'
    count++;
    if (count == 100) {
      Serial.print(".");
      count = 0;
  myFile.close();
  Serial.println("End of file. Thank you for listening!");
  while (true) ;
