Topic: How do I use a logic level converter? (Read 5810 times) previous topic - next topic
gerry87
Sorry for multiple posts, just figured they were two different topics.
I've got a sensor (http://elecfreaks.com/store/download/HC-SR04.pdf) that works off 5v, and I want to use it with my DUE - so I got one of these http://www.coolcomponents.co.uk/catalog/channel-directional-logic-level-converter-txb0108-p-1124.html
I'm wondering how to actually hook it up...
Here's my guess, could someone tell me if this is wrong?
DUE -> txb0108 <- hc sr04
3.3v -> VCCA
5v -> VCCB <- VCC
GND <- GND
GND -> OE
b1 <- trig
b2 <- echo
Pin 6 -> a1
Pin 7 -> a2
mehdio
Hi gerry87,
Never used that components but from what i read from the datasheet i noticed one mistake.
OE is 'output enable'. When it is high which means connected to VCCA (AND NOT VCCB), the output are enabled. If it is low (connected to GND), like you did, the outputs are in high impedance state thus disabled. So connect OE to 3,3V.
The rest seems fine!
gerry87
Thanks mehdio, I connected 3.3v to OE and did the rest as in my post, worked perfectly!
Vidocaz
Hello, i'm trying to use this sensor with arduino pro mini 3.3v and sparkfun logic level converter.
Could anyone help me to wire it correctly? I checked voltage with multimeter and on high side it shows zero. I have two wires from battery to low side and two wires out to hc-sr04 5v sensor (gnd nad vcc)
CrossRoads
Got a link? Need to see the schematic.
Vidocaz
Here is my schematics
CrossRoads
I don't see any schematic. I see 2 blurry humongous pictures of boards & wires with no indication of what is connected to what, or what is what even.
Can you draw a few blocks on a  piece of paper and clearly show what pins are connected to what pins? And scale it down to no more than 1000 pixels wide before you post it. You must have written something down so you could tell everything was connected when you were done, yes?
Vidocaz
Thank you. Attached new one.
CrossRoads
This is the level converter?
https://www.sparkfun.com/products/8745
You have to provide it with 3.3V on the LV pin and 5V on the HV pin.
I see voltage on one side from the battery.
I don't see the other side being powered at all.
Here's a schematic of the board
https://www.sparkfun.com/datasheets/BreakoutBoards/Level-Converter-v10.pdf
You can see where HV is an input that needs to be powered.
You are not running any signals thru the converter? What is your thoughts on what it is supposed to be doing for your circuit? It is intended to change 5V control signals down to say 3.3, 1.8V, etc, and 1.8 or 3.3V level signals up to 5V. It will not change the Power lines for you.
If you are thinking it will make 5V to power (the ping sensor?) it will not do that.
For that you need a boost regulator, such as:
http://www.pololu.com/product/2562
(and conveniently on sale!)
Vidocaz
Thank you, CrossRoads. Got the answer. Yes i'm trying to boost up voltage.
Can I use this for boost up voltage?
http://www.adafruit.com/blog/2011/07/15/new-product-8-channel-bi-directional-level-converter-txb0108/
CrossRoads
No. That is also used to change the levels of control signals.
Monoth
Very glad I read this post. Thanks very much for this, Crossroads.
I have since ordered a few of said regulators (slightly different model) for use with a 3.3v arduino and an SR04.
I was wondering if there's a schematic online to show me how to wire this before I have to come o here and ask about it? ;)
Many thanks!
