Topic: [SOLVED] Problem with sending POST data (Read 27001 times) previous topic - next topic
rufek
Sep 28, 2013, 03:16 pm Last Edit: Sep 28, 2013, 04:56 pm by rufek Reason: 1
Hello everyone,
I don't know is 'storage' the best section for my topic.
I have simple problem:
I had wrote simple php page which inserts data from POST to database.
I know, that my script is working, because I tested it on http://www.requestmaker.com/  I can send data to save into database. Program to send data on arduino does not work properly. I think, i forgot something...
I know, that POST request fires, because in database i have new records, but they are empty :( - instead of POST messages sended by http://www.requestmaker.com/
I'm using ENC 28J60 and arduino uno (but i think, that is does not matter)
Can anyone help?
Arduino code:
Code: [Select]
#include <EtherCard.h>
#define PATH    "temp.php"
byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
char website[] PROGMEM = "www.iskrzycki.hekko.pl";
byte Ethernet::buffer[700];
uint32_t timer;
Stash stash;
void setup () {
 Serial.begin(57600);
 Serial.println("\n[webClient]");
 if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
   Serial.println( "Failed to access Ethernet controller");
 if (!ether.dhcpSetup())
   Serial.println("DHCP failed");
 if (!ether.dnsLookup(website))
   Serial.println("DNS failed");
 ether.printIp("SRV: ", ether.hisip);
void loop () {
 ether.packetLoop(ether.packetReceive());
 if (millis() > timer) {
   timer = millis() + 10000;
   byte sd = stash.create();
   stash.print("t0=22");
   stash.save();
           Stash::prepare(PSTR("POST http://www.iskrzycki.hekko.pl/temp.php HTTP/1.0" "\r\n"
                       "Host: www.iskrzycki.hekko.pl \r\n"
                       "Content-Length: $D" "\r\n"
                       "\r\n"
                       "$H"),
           stash.size(), sd);
   ether.tcpSend();
PHP CODE:
Code: [Select]
<html>
<body>
<?php
$link
mysql_connect("HOST""LOGIN""PASS") or die("Keine Verbindung möglich: " mysql_error());
mysql_select_db("DATABASE") or die("Auswahl der Datenbank fehlgeschlagen");
$query "INSERT INTO table1(temp, data) VALUES ('" $_POST['t0'] . "', now())";$result mysql_query($query) or die("Anfrage fehlgeschlagen: " mysql_error());
mysql_close($link);
</body>
</html>
PaulS
Quote
Networking would have been the right place. I'll ask a moderator to move it.
You need to post ALL of your code (and describe your hardware; it is clear you are not using a WizNet based ethernet shield). Nothing in that snippet actually sends any data after the POST request.
rufek
Thanks for reply. Networking will be good :)
This is all of my code.
POST is sended by line:      ether.tcpSend();
And I know, that POSTS are sended, because in my database appears blank records - but why empty?
PaulS
Quote
but why empty?
Without seeing all of your code, I don't know. I would expect that somehow ether.tcpSend() needs to know what to send.
rufek
#4
Sep 28, 2013, 03:50 pm Last Edit: Sep 28, 2013, 03:56 pm by rufek Reason: 1
I have posted all of my code (only without HTML tags in php function).
As you see, I'm using EtherCard library. In EtherCard.h I have found:   static uint8_t tcpSend ();    - so i don't pass any parameter to this function.
I think, you are thinking about TCPSend function in wizznet, but I have enc28j60.
If I am wrong, please correct me.
Edit: I found this snippet and it is correct - so ether.tcpSend(); is a good call
Code: [Select]
[setup works fine]
void loop () {
word len = ether.packetReceive();
word pos = ether.packetLoop(len);
Stash::prepare(PSTR("MessageB" "\r\n"));
ether.tcpSend();
So I think, that problem is in my POST message - maybe are some quotation marks missing or something like that... But no idea, where
PaulS
Quote
No, you haven't. Until you do, this is my last reply.
rufek
#6
Sep 28, 2013, 04:07 pm Last Edit: Sep 28, 2013, 04:13 pm by rufek Reason: 1
I modified my php code - HTML tags added. Also I attached arduino project and php file to first post. I can't show more, because this is all of my code - If any instruction is missing, you can tell me about it.
Edit: Database 'select' screenshot also added to first post
rufek
#7
Sep 28, 2013, 04:39 pm Last Edit: Sep 28, 2013, 04:48 pm by rufek Reason: 1
Solved!
Post message must contain 'Content-Type'
Working code for arduino:
Code: [Select]
uint32_t timer;
Stash stash;
void setup () {
void loop () {
   stash.save();
                       "Content-Type: application/x-www-form-urlencoded \r\n"
                       "\r\n"
                       "$H"),
           stash.size(), sd);
   ether.tcpSend();
PaulS
Quote
Resolved !
Excellent. I've never used POST. What you are doing could be done with a simple GET, and would, in my opinion, be simpler. Yes, GET requests are easier to sniff, but how the temperature somewhere could be considered sensitive, I do not know.
You could add [SOLVED] to the original thread title.
kimjessen
Hey sorry I start this up again.
but a little question.
if you need to send a sprcifik port, such as port 8004 => xxxxxxx.dd: 8004
how would you do this.
ArduinoStart
I have been struggling now for two day's to pass data to my website using Microsoft, I see you got it right I have tried everything, but no luck.  Could you help me?
ArduinoStart
Hi again,
If I go and type this in the browser www.manski.co.za/default.aspx?id=123 then it works and it inserts the 123.  If you see anything wrong with my code please give advise.
Thank you
// your variable
#define PATH    "default.aspx?"
#define VARIABLE    "testing123"
// ethernet interface mac address, must be unique on the LAN
char website[] PROGMEM = "www.manski.co.za";
uint32_t timer;
Stash stash;
void setup () {
  ether.printIp("IP:  ", ether.myip);
  ether.printIp("GW:  ", ether.gwip);
  ether.printIp("DNS: ", ether.dnsip);
void loop () {
    stash.print("?id=");
    stash.print(VARIABLE);
    stash.print("&action=Submit");
    stash.save();
    // generate the header with payload - note that the stash size is used,
    // and that a "stash descriptor" is passed in as argument using "$H"
    Stash::prepare(PSTR("POST http://www.manski.co.za/default.aspx" "\r\n"
                        "Host: $F" "\r\n"
                        "\r\n"
                        "$H"),
            website, PSTR(PATH), website, stash.size(), sd);
    // send the packet - this also releases all stash buffers once done
    ether.tcpSend();
