Topic: Best way to count the frequency and duty cycle in same time. (Read 2689 times) previous topic - next topic
Gytis
Sep 28, 2013, 09:43 pm Last Edit: Sep 30, 2013, 04:51 pm by Gytis Reason: 1
Hello, I'm a new guy here, recently I started making a new project with arduino, but I have some big issues. In general, I need to count 2 different PWM signals at the same time, but I can't make it work. I have written and tested one code:
Code: [Select]
 FreqPeriod::begin();
 injector = pulseIn(11, HIGH);
 pp=FreqPeriod::getPeriod();
 if (pp ){
   lfrq= 16000400.0 / pp;
   if (injector != 0)
           pulse_time_counter += injector;
      if(currentMillis - previousMillis > interval)
              Serial.println(pulse_time_counter);
             Serial.println(lfrq, 1);
      Fuel_amount = 0.0104*(pulse_time_counter / 1000000.0);// there, "pulse_time_counter" I could change in duty cycle.
      Litrazas = (Litrazas + Fuel_amount);
      Distance = 100/(lfrq/5000.0);//5000!
      Moment = (Fuel_amount * Distance);
      speed_sensor_counter = 0;
      pulse_time_counter = 0;
                 u8g.firstPage();
         do {
              draw();
         } while( u8g.nextPage() );
However, this code is working incorrectly, because I have calculated that the "Moment" should be 26, instead it(arduino, ar kas? nu žodžiu ?sirašyk pats vietoj "it" kas ?ia yra) counts only to 24. "Moment" data is sent to LCD, which works in a manner of u8g library. Maybe I should use Time interrups for "pulse_time_counter" in one 1s, rather than using PulseIn function? Instead of using "pulse time counter" I'm ok with interrupt calculating "duty cycle" expressed as a percentage.
robtillaart
1) please use CTRL-T before posting, that makes your code far more readable.
2) please post the whole code, noone can compile snippets.
3) provide links to libraries used, not every one has the same as you.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Gytis
#3
Sep 30, 2013, 04:51 pm Last Edit: Sep 30, 2013, 04:53 pm by Gytis Reason: 1
Code: [Select]
#include "U8glib.h"
U8GLIB_ST7920_128X64 u8g(7,9,8, U8G_PIN_NONE);
#include <DS1302.h>
DS1302 rtc(2, 3, 4);
#include "FreqPeriod.h"
double lfrq;
long int pp;
volatile unsigned long injector = 0;
long pulse_time_counter = 0;
   long previousMillis = 0;        // will store last time LED was updated
   long interval = 1010;
     volatile unsigned long speed_sensor = 0;
       volatile unsigned long speed_sensor1 = 0;
   static float Fuel_amount = 0;
   static float Distance = 0;
   static float Distance_1 = 0;
   static float Moment = 0;
   static float freq;
   static float Litrazas = 0;
   static float Kilometrazas = 0;
  long speed_sensor_counter = 0;
void draw (void) {
   u8g.setFont(u8g_font_5x7);
   u8g.drawStr(73,10,"Time");
   u8g.setFont(u8g_font_fixed_v0);
   u8g.setPrintPos(96,10);
   u8g.print(rtc.getTimeStr(FORMAT_SHORT));
if (Moment < 10.0)   {
       if (Litrazas < 10.0) {
       // sitas L/km paisyti.good one
       u8g.setFont(u8g_font_freedoomr25n);
       u8g.setPrintPos(10,40);
       u8g.print(Moment, 1);
       u8g.setFont(u8g_font_6x10);
       u8g.drawStr(61,38,"L/");
       u8g.setFont(u8g_font_6x12);
       u8g.drawStr(72,38,"100km");
       //linija po skaiciais
       u8g.drawHLine(6,44,105);
       u8g.drawVLine(105,41,10);
       //economy
       u8g.drawStr(7,60,"Fuel_economy:");
       u8g.setFont(u8g_font_freedoomr10r);
       u8g.setPrintPos(75,62);
       u8g.print(Litrazas, 1);
       u8g.setPrintPos(97, 60);
       u8g.print("L");
       else if (Litrazas > 10.0) {
       //economy
       u8g.setPrintPos(104, 60);
       u8g.print("L");
   if (Moment > 10.0) {
         u8g.setPrintPos(5, 40);
         u8g.drawStr(75,38,"L/");
         u8g.drawStr(86,38,"100km");
         u8g.drawHLine(6,44,119);
         u8g.drawVLine(119,41,10);
         // Fuel
         u8g.print("L");
         u8g.print("L");
 if (pp ){
   if (injector != 0)
      Fuel_amount = 0.0104*(pulse_time_counter / 1000000.0);//Cilindru skaicius is 0.0026=0,0104L
              u8g.firstPage();
         do {
              draw();
To test code, I use two generators in my university, each one giving 100Hz 50% pulse to arduino. Libraries: u8glib for lcd, for real time module I use DS1320 library and for frequency I'm using http://interface.khm.de/index.php/lab/experiments/frequency-measurement-library/. And finally, for pulse duty, I using pulseIn function. Can you sugesst for me, some library that could count pulse duty with arduino interrupt?
